Why does my phone say messenger stopped working or mainframe stopped working?
Zyxel router P - 330W EE continuously overloads and disconnects from the internet
mainframe computer? You have a business? Your ISP may be "throttling" your data.
Jan 04, 2013 | Zyxel Computers & Internet
I want to see ip address of vse mainframe how to check any one suggest me how to find out ip address please
Open a connection to the VSE mainframe, and logon.
Click Start
Click Run
Type CMD
Press Enter
Type NETSTAT -a -n
Press Enter
Look for a line of output like:
TCP my.ip.address.goes.here:mmmmm remote.ip.address.here:23 ESTABLISHED
i.e,. look for 'TCP' and ':23' and 'ESTABLISHED'.
The value of "remote.ip.address.here" is the IP-address of the mainframe.
Apr 22, 2011 | Computers & Internet
Need instructions on how to transfer a file from the PC to the Mainframe. Everything I have found leaves out a step or discribes it in developer language.
What type of mainframe are you referring to and what type of file do you want to transfer? How large is it, etc. Typically you would use ftp to transfer the file. If the mainframe is a IBM/Hitatchi type, you may need to convert the file to EBCEDIC. More likely, the mainframe is a type of Unix machine. It that case you probably want to send the file through ftp as ASCII. That should convert the line ending characters from CR/LF to LF. There are other transfer methods, but ftp is the easiest.
Sep 17, 2009 | Microsoft Windows XP Professional for PC
Instant messenger error
you can check the settings ,,,
or then finally you can reinstall the messenger...ok
Apr 15, 2009 | LG Vu CU920 Cellular Phone
My yahoo messenger has stopped working
I had this problem till yesterday. The culprit was some ad script in the messenger ads has stopped working because it was not compatible with my flashplayer. As a result I got the message that messenger has stopped working. Download and install the latest version of flashplayer to resolve this issue. This issue has been fixed in messenger 9.
Nov 25, 2008 | Yahoo Messenger
My yahoo messenger has stopped working!!
can you help me about my problem? regards and god bless you
Nov 03, 2008 | Yahoo Messenger
Windows live messenger and Yahoo messenger has stopped working
you can have as many IM's as you like installed, although i would only use 1 at a time, try doing a java update and reinstalling live messenger, then do a microsoft update
Oct 29, 2008 | HP Pavilion DV5234US Notebook Laptop
my yahoo messenger has stopped working i have vista please sen my the solution
Oct 21, 2008 | Yahoo Messenger
Yahoo messenger stop working on my laptop
I had the same problem... I have a Dell Inspiron B130 Laptop. The only thing that worked for me was to do the following: Click START click CONTROL PANEL click ADD AND REMOVE PROGRAMS scroll to Yahoo Messanger, click on it, and it should have a option to repair. Click on that, and follow the step-by-step instructions. GOOD LUCK!!!
Oct 15, 2008 | Yahoo Messenger
PRINTER WONT FAX AND WON'T STOP PRINTING
Hello Ncerritos. I have an ideaj that may help. First disconnect the AC power. Second disconnect the RS232 or interconnect cable to the mainframe and look for bent pins in cable or socket. If you find pins bent I worn you they are no very fexable. If it is the cable it would be safer to replace the cable, If its the socket you may try straighting CAREFULLY. I wish you luck on this ventur.
Sep 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
