Question about Video Cameras
How do I recover from HDD error E:31:00?
Not able to open or delete nor format
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Google it
Posted on Mar 18, 2016
3 Suggested Answers
  • 30 Answers
SOURCE: Need to recover deleted videos from HDD
When you delete files the data itself isn't deleted, just the index entry that tells the system where the data for those files is located. The area containing the deleted data is also now marked as free space so it is available for any new files to be written there instead.
So most of the time, you are able to get back deleted files from computer. You may try a free data recovery software to view deleted files so that you know whether the deleted files are recoverable.
One I used to use is asoftech data recovery program which you can download from site below
http://www.asoftech.com/adr/
Posted on Oct 14, 2012
  • 30 Answers
SOURCE: Media recovery
OK! Be relaxed! Nowadays, the deleted files on a camcorder are not actually destroyed immediately as we think. They still can there and become invisible. So, act carefully to get these deleted pictures back:
1. Stop using this camcorder right now in case that any new file on it may overwrite your deleted files.
2. Insert this camcorder to your computer.
3. Download a camcorder data recovery freeware to retrieve all your lost files back.
This professional camera recovery freeware has helped many people around me restore their inaccessible data off from a phone/camera memory card or hard drive. It could be a good choice for you to go on.
Try to read more detailed information of this camcorder data recovery freeware here:
http://blog4mark.blogspot.com/2012/12/deleted-files-recovery.html
4. Do not save or back up all the restored data on the camcorder in case of any data loss
Posted on Sep 06, 2013
Hdd fault hard
Formatting could easily destroy the entire contents of the hard drive. It should be used with extreme caution. To be more selective, go to settings, then programs and uninstall what you do not need. If you formatted in error, do not do anything more with your drive if you want to recover precious data or files. Instead take it to a data recovery service. Or use a bootable tool like EASUS link below if you are an advanced user. Every mis-step risks inability to recover files. How to Undo Quick Format on Hard Disk
Feb 28, 2018 | LG Televison & Video
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Sony handycam DCR SR65 HDD format error E31:00
Recently purchased a camcorder DCR-SR68 and we took all our wedding video on it. It now says HDD format error and all my video is gone. I tried resetting didn't work, took out the battery, didn't work. Sony told me to format the drive but that also not function. couldn;t format that.
Is it possible to recover this video??? can i solve that problem?
please send to solve that problem
Aug 09, 2010 | Sony Handycam DCR-SR100 Camcorder
Sony DCR SX40: internal memory format error
You may try a video recovery software, recommended asoftech data recovery as it helped me before. use link below to download:
Camcorder video recovery software
You may refer to this video tutorial
Mar 06, 2010 | Sony Handycam DCR-SR40 Camcorder
Sony dcr-sr47 handycam - hdd format error.
Does this camera also take a memory card? If it does, then that would mean the internal memory would be very small...much too small for a long video. If it doesn't, then it's possible you should have formatted the internal memory before an important event.
Dec 18, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
HDD error, full disk, camera temp is too low
I have had success with this... Download the camera recovery software called asoftech data recovery
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Nov 14, 2008 | JVC Everio GZ-MG37 Camcorder
Data Recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 10, 2008 | Iomega HDD External Desktop (32660) 80 GB...
Recover erased data
Ok,
Thanks
Nov 02, 2008 | Sony ICD-B10 Handheld Digital Voice...
Media recovery
Thanks
Feb 19, 2008 | Sony Handycam DCR-SR40 Camcorder
Video Cameras Logo
82 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
