Question about Kenmore Refrigerators
Interior light will not work even after replacing bulbs
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Possibly door switch not working
Posted on May 05, 2015
The right hand interior light on my Sportage has stopped working. The left hand one works but no the right hand
I believe there is a diode in the wiring to the bulb! Trace the wire and feel for a bump in wiring and check/replace diode!
Nov 23, 2014 | Cars & Trucks
HOW DO I REMOVE INTERIOR LIGHT FIXING TO REPLACE BULB?
Try twisting it. Even maybe push in and twist bulb.
Jul 04, 2017 | Refrigerators
My Camry 99's gear shift indicator light, ciggarette lighter light, Air con's contoller light and ash tray lights are not working after replacing bulbs.
Could be a fuse. Check the interior firewall fuse box under the driver's side dashboard area. That's location of the fuse box. Probably wired in series....maybe wrong bulb replaced.
Dec 02, 2017 | Cars & Trucks
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
GE microwave JES 2251 SJ02 Light bulb that illuminates oven interior burnt out. Have correct replacement bulb (I think!). Can I remove oven cover and replace light bulb while keeping a good distance away...
sTEVE, THE CAPACITORS HOLD A CHARGE EVEN AFTER THE SYSTEM IS UNPLUGGED. A good rule of thumb would be to allow at least 48 hours for the capacitors to discharge before even getting nea them. Then, yes, you can replace the bulb. Thanks
Jan 27, 2011 | GE Microwave Ovens
I got a 2002 ford taurus and when i go to turn my headlights on the interior light dont work and the blinkers light up but they do blink when im turning, i was what it could be thats causing that thank...
Many turn signal lamps will have multiple bulbs in them. If "one" of the bulbs is faulty, the interior lamp or lamps will come on, indicating a bad bulb. You will need to turn on your left blinker and view the bulb and make sure all bulbs appear to be blinking on front and rear of the car, then repeat with the right blinker. If you find one that doesn't appear to look right or blinks faster slower or dimmer, then replace the bulbs in that turn signal. The interior light may begin working properly when you replace the "shorted" bulb for the turn signals. If it does not, check the fuses to make sure the "shorted" bulb didn't damage your fuse for the interior lights.
Jul 01, 2010 | 2002 Ford Taurus
Interior light out. replace bulb
Ifthe owner's manual doesn't cover it and there's no obvious coveron the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
The light is often located on the right side in the air duct attached to the magnetron or above the cooking cavity.
Mostbulbs can be matched up at hardware stores, home improvement centers,and places like Wal-Mart or even large grocery stores.
Sep 17, 2009 | Siemens Microwave Ovens
How do I replace the Rear Brake light bulb of 2001 Toyota Sienna?
I have a 2001 Sienna and have had to replace most of my tail light bulbs.
The bulbs that are mounted in the fender (wrap arounds) have acess panels in the van's interior that easily pop out and expose the back of the light assembly.
However, the bulbs that are found in the lift gate are a different matter. You have to remove the whole interior panel to the lift gate to expose the light assemblies. Go to your auto parts store and get a tool to help pop out the plastic retainers from the lift gates metal frame. Don't force the retainers out. Go slowly and gently so that you don't damage the interior panel. If you are really gentle you might even get to reuse the retainers.
Jun 08, 2009 | 2001 Toyota Sienna
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
