Question about Refrigerators
My fridge starting after some time stopping and not starting it self unless switch off power supply and then on it will again in auto
  • Refrigerators Master
  • 5,323 Answers
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
My fridge starting after some time stopping and no - 25674854-5dbacpjug1urbtduyx4ujsps-1-1.jpg
25674854-5dbacpjug1urbtduyx4ujsps-1-4.png My fridge starting after some time stopping and no - 25674854-5dbacpjug1urbtduyx4ujsps-1-8.jpgt/uploads/images/25674854-5dbacpjug1urbtduyx4ujsps-1-8.jpg" alt="25674854-My fridge starting after some time stopping and no - 25674854-5dbacpjug1urbtduyx4ujsps-1-13.jpg_mi" />
My fridge starting after some time stopping and no - 25674854-5dbacpjug1urbtduyx4ujsps-1-26.jpgmages/25674854-5dbacpjug1urbtduyx4ujsps-1-19.jpg" alt="25674854-5dbacpjug1urbtduyx4ujsps-1-19.jpg" class="h_mi" />
Posted on May 17, 2015
2 Suggested Answers
  • 291 Answers
SOURCE: Fridge stopping and not starting unless i will switch power supply off then on again
when was the last time you pulled the front grill at the bottom and cleaned it out? or had it serviced, most times they come in with a air compressor and blow the coils free and everything is back to normal, I clean mine twice a year, have a special 20 dollar tool bought from parts store.
Posted on Apr 30, 2015
I have a 17k generac generator when it auto comes on the motor runs rough but when manually turned on it will run fine.
Could be the load you have on it is to much for when it does it it self .when you do it do you turn power off then start it and then putt the power back on .then it would run easy every time .could be your back up battery for it is to small .is it on a transfer switch like it should be when it starts it self .
Mar 30, 2017 | Generac Electrical Supplies
I unplugged my fridge to plug it into a power strip (so I could also plug my microwave into that plug), and when I turned it on again it's not making noise. Did I hurt the fridge?
should not have
I would suspect that the power strip reset overload button popped or there is a problem in the power supply
unless the fridge did not need the compressor running as it was cold enough and the compressor had stopped as per the cycle
Oct 16, 2015 | Refrigerators
Apr 30, 2015 | Refrigerators
I have two Bosch fridges. I just bought this house and there is nothing in either fridge. Worked day we took possession of home, but both stopped working. They have power just won't cool.
Bosch is a high end manufacturer of appliances. Occasionally things can go wrong, such as fluctuations in temperature. Bosch's policy is to charge for calls to customer service advice, even when the appliance is still under warranty, so it's worth trying these troubleshooting steps before making the call. Bosch refrigerators also have an appliance self-test which you can run.
Instructions
    • 1 Check that the plug is inserted into the household power outlet at the wall. If there's no text displayed on the display panel, it is because there is no power to the fridge.
    • 2 Make sure that the door hasn't been left open if the warning signal sounds. The warning signal means the temperature is rising, and frozen food can be at risk. Visually inspect that the ventilation openings aren't covered by household objects, debris or dirt. Press the "Alarm Off" button to switch off the alarm.
  • 3 Ensure that the temperature controls are set correctly if the fridge or freezer compartments get too cold.
  • 4 Check that the water supply is on if the ice-maker isn't producing ice. Test the water supply by using the water dispenser on the door. If "IWD Off" is displayed on the panel, the ice and water are supplies are off and need to be turned on again.
  • 5 Press the "Condensation Heating" switch near the ice dispenser and water outlet on the door if condensation forms on the outside of the refrigerator. If the environment around the refrigerator is too humid, the appliance can compensate for that.
  • 6 Run the self-test program to identify major faults. Switch the refrigerator off and wait five minutes. Switch the refrigerator on again. Press the "Select" and "Options" buttons at the same time for five seconds. The self-test will commence. Keep an eye on the display. "E" indicates a fault which needs reporting to customer service. The number in the US is 1-800-944-2904.
  • http://www.ehow.com/how_5769746_troubleshoot-bosch-refrigerators.html
  • Nov 27, 2014 | Refrigerators
    My samsung refrigerator goes off everytime the electricity flickers, even for a flash or less than a second. It goes off and it does not comebacks on for as much as 24 hrs. Sansumg's technitions says...
    The fridge can cut off if there is a power flickering or variation as the relay will be energised to trip off. Once the fridge is off the self timer - 5 minutes- will be active to allow the gas/oil to come back to the compressor as the flickering would have produced an irregular pumping.
    After about 5 minutes the processor will energise the relay to contact and start.
    Now the main issue is the voltage in your household. if the voltage is low then the fridge will not start again as it will click and shut off. So make sure that there is sufficient voltage in the mains supply. Also the plug point where the fridge is connected must deliver good voltage/current as the wiring must be good to carry the load . If not the fridge will trip off whenever there is a power flicker.
    Finall if the power is good then the fridge mut be checked as it cannot be off for 24 hours. register you complaint for warranty service.
    If power is irregular use an auto- voltage stabiliser .
    Aug 09, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
    Hi i have a mirai 37in tv. Its great apart from after 1 hour maybe more it turns itself off, the on/off switch flashes and a clicking noise can be heard. It will go on again after turning it off but does...
    No,do it ur self by replacing the power supply board part about $100-110+shiping.This problem can fix by replacing the power supply board.That the board where the ac power cord go into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
    May 27, 2010 | LG 37LC7D 37 in. LCD HDTV
    Hi - took it off for 36 hrs - never had an issue - oyster submariner not moving now ... thanks for your help
    This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
    Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
    Hope this helps.
    Ken
    Yellowstone Watch Inc.
    www.yellowstonewatch.com
    Oct 27, 2009 | Rolex Day-Date President 118238 Wristwatch
    Player shutdown and then go to self check
    unit goes in to self checking over and over dvd can not be ejected and will not function at all?
    Aug 05, 2009 | Panasonic DMR-E55 DVD Recorder
    Power supply Ok.But CPU fans started with seconds It's stop.
    sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
    Feb 15, 2009 | Asrock P4S61 Motherboard
    Side by Side fridge stops cooling and the works again !
    soiunds like the defrost timer is bad, Unless your highly mechanically inclined I would go ahead and call out the service repair company and tell them to be sure to bring allong a timer fo your unit. Hope this helps and good luck.
    Jan 09, 2009 | Whirlpool ED2FHGX Side by Side...
    Refrigerators Logo
    48 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
