Question about Shark Navigator Professional Lift-Away Vacuum w/ Bonus GI568 Iron
All filters are clean, but still no suction. Emergency suction valve as soon as it starts up
  • 1,140 Answers
There is a plugged hose or plug near where the bag attaches to the vacuum cleaner.
Posted on Oct 12, 2015
We have a tefal ironing station and it has developed a fault the steam is continually on and the green light is continually flashing can u help
The problem is caused by a blockage in the steam regulating valve. try the 50:50 vinegar solution as described above, If this does not work then you need to take out the valve and clean. IT is pretty simple. Remove the bottom of the base station and you will see a rectangular box with tubes coming out of it. This is the steam valve. Dismantle and clean and you should be good to go. whole job should only take 15mins
Mar 24, 2015 | Tefal Irons
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
My shark navigator is getting hot
Yes, tear it down as far as you can and make sure there are no obstructions- take it apart as shown in the manual and run warm water through all the hoses to clear them.
They're like an artery and the more they get clogged the more heat the motor will have to generate to make suction.
Also check the beater bar and make sure there's no strings, etc. hung up under there- use a box cutter to carefully cut any tough strings and see how you do.
Chances are, that's all you need.
-Jim from Shark Navigator reviews
Nov 16, 2012 | Shark Navigator Professional Lift-Away...
The temperature of the boiler is not controlled normally and the safety valve opens. I suspect that the temperature control sensor is not functioning properly, and if this is the case where can I find a...
see this causes and use the common sense. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Sep 19, 2012 | Rowenta Irons
"My rowenta DG9540 iron won't stop steaming. It starts as soon as it is switched on regardless whether the steam button is pushed in or not. What might the problem be?"
1) check the ejection button of the stems for particles, has blockage the mecanism by using hard water to due mineral deposit clean it.
2) other wise you must go to some repair shop for fix it.
God bless you
Jul 11, 2012 | Irons
My tefal pro express which i have had for 6yrs and ive had no trouble has started leaking dirty brown water can you tell me where i can take it to get it fixed in birmingham please.
I opened the side valve, (not when there is hot water within as it will explode in your face) and rinse the water from here. That worked for me.
The problem is the limescale it think which needs to be regularly cleaned out.
hope this helps.
Mar 27, 2011 | Irons
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
Continuous steam and green light flashing on my tefal steam generator iron.
I found this on a site and it works!! Put 50/50 mix of water and viniger in your iron, let it run, after a while start pressing the steam button, you may have to do this a few times, but it will eventually stop the light flashing, then the steam function will return to normal. You'll need to clean the iron out a few times afterwards
Jun 22, 2010 | Tefal Pro Express GV 8120 Iron
Hi, I have been given a Euro-Pro Ironing Solution EP1005 without a manual where do I put water in for steam & how does the suction work Marj
I don't know that system, but you're real lucky, that type of irons are fantastic! Most such have something that looks like a big black knob (you can see the same type e.g. on steam cleaners). You screw it counter-clockwise until it opens. Then you fill it up with water through the little hole. That type of valve is the one I have seen the most on pro systems, while my own home type generator iron only has a tank you simply pull off so you can fill it under the faucet. I have no idea how the suction works, except for it being real great as it helps draw the steam through the garment and away, so it gets dry instantly. I'm sure it also allows you to use a lot more steam, e.g. on tough wrinkles...
Why don't you go to the Euro-Pro website, mail them and ask for their help in getting a manual for it? Or maybe you already tried that? If you look around, you might be able to get a downloadable manual from one of the many manual sellers online...
Oct 27, 2009 | Euro-Pro EP1005 Iron
Rowenta Iron DG-980 problem
you should have a controll or button on the iron that tells it to release the steam. make sure that the button or controll is not stuck.
Aug 03, 2008 | Rowenta DG-980 Iron
Shark Navigator Professional Lift-Away Vacuum w/ Bonus GI568 Iron Logo
184 people viewed this question
Top Shark Irons Experts
thinksewfast
ray gallant
Tom Chichester
Are you a Shark Iron Expert? Answer questions, earn points and help others
