Question about Dell Studio XPS 16 Notebook
How do I get a meter reading for my copies? - Dell Studio XPS 16 Notebook
    Sergeant:
  • Dell Expert
  • 352 Answers
Hi Laura Garcia,
Please share the printer model then I can check and let you know if this option is available or not.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Posted on May 04, 2015
How to rest meter reading of xerox 5020Dn
There's no way to reset the meter read, unless u replace the hole mainboard.
Feb 10, 2015 | Xerox 5020V_U WorkCentre 5020...
The meter on our Savin increased 5x the normal color reading in one month and we haven't used the copier any more than normal. Our paper consumption hasn't gone up, nor our toner consumption....
Could it ???? That's a good question... I have seen the meter stop working. I don't know, but did anyone try to manually change the hard counter? Maybe your service company may have your copier set in service mode to click twice for 11 x 17 or for two sided copies? One test you can do is to write down the meter reading and make ten copies and recheck the meter. If it clicks ten times, the meter is working and try making four 11 x 17 copies and look at the meter to see if it clicked four times. If the meter is working correctly, your service company is ripping you off or they are billing the wrong company.......
Mar 22, 2013 | Ricoh Aficio 450 Copier
Where is meter reading on canon imageRunner C5180i color copier?
Hi sophie,
Look to the far right of the operator contol panel, past the 9 key pad and you will see a "little button" called COUNTER check. Press it and it will tell you your meter reading.This screen can be configured "by a service tech" to allow you to view the count of up tp 6 different meter counts depending on the function you wish to monitor. The basic meter reading is named "101". That because there are hundreds of funtions that are always monitored and they name them 101,102,103 etc. 101 counts the number of sheets of paper that have exited the copier. "102" does the same except it counts 11x17 [ledger] as 2 copies as 11x17 is really 2 letter size sheets. So my company uses this meter for billing purposes so we ADD the 102 meter to the list of viewable meters. Again this can be configured to the customers needs or the service provider needs. You can set it to view just black and white, just color, or even how many copies were made at 64%. its wild. But the 101 meter is the default and cannot be removed or altered. I sure how I helped you. Please let "FIXYA" know.The pat me on the head when I do good. :-) Take care . SPINAL
Jan 28, 2011 | Canon imageRUNNER C5180i Color Copier
I have the bizhub C352 - I want to print the utility/counter (meter readings). How do i do that. Previous machines had me go to Utility - admin management - copy track - Copy track data - & hit the...
to print meter readings perform these steps. 1-press "utility/counter" 2-press "details" 3-now at the left side of the screen you will see a "print" button, press it and get your copy.
Oct 20, 2010 | Konica Minolta bizhub C250 All-In-One...
Where to find meter readings on workmate m20i
You have to press the machine status button.
Scroll to" reports"then to "billing meter."
Then press enter and it will print out the total pages printed/copied.
There is no meter per se on the M20. You have to print out the reading on the report.
Jan 11, 2010 | Xerox WorkCentre M20i All-In-One Laser...
How do you get a meter reading on a pansonic 8020?
Press copy size and paper tray keys down at the same time.Meter Reading will show on the screen.
Oct 21, 2009 | Panasonic DP-8020E Black and White Copier
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
How can I get a meter reading from an AR-M237?
press and hold the the button that says "copy" on it next to the screen, the meter should show on the screen
Dec 05, 2008 | Sharp AR-M237 Copier
Copy count
You should be able to get the meter reading on a 7022 by pressing the star key (*) on the numeric keypad.
Hope this Helps
May 12, 2008 | Office Equipment & Supplies
Canon NP 6050 Copier - number of copies
I would say that is not the correct meter. The meter is only 6 digits long, maybe 7 it's been awhile scine I looked at one. You probly have a meter of 0136012. There is only one hard counter / meter in the copier. It's not even the serial number?? Good luck
Apr 30, 2008 | Canon NP 6050 Copier
Open Questions:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.OverflowException: Value was either too large or too small for an Int32. at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at BmLauncher.SystemInfo.GetPropertyInt(ArrayList info, String propertyName, Int32 property_index) at BmLauncher.SystemInfo.GetPropertyIntBest(ArrayList info, String propertyName, Boolean select_highest) at BmLauncher.SystemInfo..ctor() at BmLauncher.Form1.Initialise() at BmLauncher.Form1.OnLoad(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6407 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- BmLauncher Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Eidos/Batman%20Arkham%20Asylum%20Demo/Binaries/BmLauncher.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6402 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Oct 20, 2013 | Dell Studio XPS 16 Notebook
Dell Studio XPS 16 Notebook Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
