Slow water leak rear left of machine only when operated
Took it apart-- hoses to the various dispencers seem to be very wet but is this normal--water is running down the sides of the machine to the drip edge on the bottom then to the floor
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check hose under soap despencer drawer
Posted on May 01, 2015
Water leaking from under washing machine. Took off cover. Hoses ans water pump look good. Seems water is leaking on spin cycle above the transmission.
90% of the time the water leaks from either the drain pump module or motor, or through the centre seal and bearing.Couple of not so common areas are the various pipes:small holes in the drum:the soap dish etc. Possibly remove the lid and place the washer on 4 bricks and then run the machine so you can pinpoint the area.
May 20, 2010 | Washing Machines
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Trunk water leak 1993 buick park avenue
Mother nature is too slow in finding leaks. Have someone small get in the trunk with a flashligh and watch as you run a hose over everything. LET THE PERSON OUT!
Jun 11, 2009 | 1993 Buick Park Avenue
Kenmore HE 3t started leaking from the side when filling
check dispencer and make sure its not cracked,,if not turn your water pressure down to the dispencer its splashing up and over running down..keep me posted onthejob
Jan 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Bissell 7901 proheat service manual
I took apart the cleaner to clean the parts that were dirty and I can't seem to put the roller back in. Any suggestions
Aug 14, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
Leaking dishwasher
when you state "there is water leaking out of the drain hose", then that leak must be fixed either by a new hose or to repair the hose. as far as the timer issue, i need more info.
May 25, 2007 | Maytag 24 in. PDC3600A Built-in Dishwasher
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
