Wash tank water leakage slowly slowly what is the reason
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Probly hose dont know if its top or front loader
Posted on May 01, 2015
We have a LG Fuzzy logic 5.0kg WF-T507. When not working, cold water is slowly leaking into the tub. The hot water is also not flowing when needed.
The fill valve could be defective but the leakage into the machine when idle could be caused by supply line(s) above the fill valve level. Some manufacturers recommend turning off the supply between wash sessions but in practice that tends to be impractical.
Feb 12, 2017 | LG Washing Machines
Miele w310..drum fills with water slowly after a wash.put my head in...cant hear water leaking into it..
Did you open the water tap complete? When it is open all the way already, please close the tap complete and remove the hose and check the filter closest to the tap. Eventually clean it and put the hose back. Don't forget to open the tap again and check you did tighten the hose. (No leakage)
Feb 04, 2015 | Miele W310 Front Load Washer
Hoshizaki am-25ae. We have inherited a AM-25AE with the lodge we bought and it works just fine. We do want to give it a very good clean inside and disinfect the whole water 'way' to ensure the ice won
Cleaning Instructions:
Water System
1) Dilute approximately 5 fl. oz. (148 ml) of recommended cleaner Hoshizaki " Scale Away" or "Lime-A-Way" ( Economics Laboratory, Inc) with 1 gal. (3.8 lit) of water.
2) Remove all ice from the Evaporator and the storage bin. Note: To remove cubes on the evaporator, remove the front panel ( Lower), move the control switch on the control box to the "OFF" position and move it back to the "ICE" position after 2 minutes. The harvest cycle starts and the cubes will be removed from the evaporator plate.
3) Move the control switch to the "OFF" position. Close the water supply line shut-off valve.
4) Remove the water tank to drain the water. Refit the water tank in its correct position.
5) Slowly pour the cleaning solution into the water tank.
6) Move the control switch to the "WASH" position.
7) After circulating the cleaner solution for about 30 minutes, move the control switch to the "OFF" position.
8) Remove the water tank to drain the cleaning solution. Refit the water tank in its correct position.
9) Open the shut-off-valve.
10) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
11) Move the control switch to the "OFF" position and immediately back to the "WASH" position to rinse water.
12) Repeat the above rinse procedure three more times to rinse thoroughly.
13) Dilute approximately 0.5 fl. oz. (14.8 ml) of 5.25% sodium hypochlorite (Chlorine bleach) with 1 gal. (3.8 lit) of water.
14) Move the control switch to the "OFF" position. Close the water supply line Shut-off-valve.
15) Remove the water tank to drain the water. Refit the water tank in its correct position.
16) Slowly pour the sanitizing solution into the water tank.
17) Move the control switch to the "WASH" position.
18) After circulating the sanitizing solution for about 15 minutes, move the control switch to the "OFF" position.
19) Remove the water tank to drain the sanitizing solution. Refit the water tank in its correct position.
20) Open the shut-off valve.
21) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
22) Move the control switch to the (OFF) position and immediately back to the "WASH" position to rinse water.
23) Repeat the above rinse procedure two more times to rinse thoroughly.
24) Move the control switch to the "ICE" position, and start the automatic ice making process. Refit the front panel (LOWER) in its correct position. abut do not forget to wash and sanitize the ice bin.
Sep 01, 2014 | Kitchen Appliances - Others
What is wrong with my lg dishwasher it is flashing E1
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage.
Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
see http://www.appliancepartsquick.com/LGDishwasherFaultCodes.html and
http://www.fixya.com/support/t193162-error_code_e1_lg_dishwasher
Jun 23, 2014 | LG 24 in. LDF 7811 Stainless Steel...
E1 message on smeg DWI 614
see this causes and fix it. God bless you
E1--Leakage error--Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection (sink drain hose) is not over 20". Impeller of the washing pump is worn away
Sep 28, 2012 | Dishwashers
Error code E1
E1...LEAKAGE ERROR-displayed-
The excessive RPM of
Washing Motor
happened during Wash
cycle due to water
leakage.
Water leakage in Hose connections.
Water is leaked by damages.
The Motor Water Seal leakage of
Sump assembly.
The height of Drain Hose connection
(sink-Drain Hose) is not over 20 .
Impeller of the Washing Pump is
worn away.
Replace the connections of Hose.
Check the point of damages and
repair or replace the related parts.
Read the Installation Instructions
(page 9) and fix it to the
recommended Height.
Replace the Impeller of the
Washing pump
this is from your manual any more questions please message me back thanks again
rickead1
Sep 02, 2010 | LG WM2487H Front Load Washer
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
E1 comes up on screen and alarm goes off, how do I fix it?
Leakage error > Condition: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Solution:
Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
Mar 25, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
Getting error message E1 what does this mean
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Sep 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
