Question about Zonet ZFS3008 (ZFS3008-04)
Zonet ip address
I need the ip address for this router to enter a new password.
  • Zonet Master
  • 3,320 Answers
192.168.0.1
Both default user name and password is admin.
http://setuprouter.com/router/zonet/zsr4154we/manual-915.pdf
Posted on May 15, 2015
How to reset password
Look on the side and bottom of the router and see if there is an ip address that you would put into your internet browser to get into the router. It will be something like 192.168.1.1
Once you get into the router you will need to enter the user id and password then go to the Wireless Security Tab and change or enter the password.
If you don't know the ip address then search your manual. If you don't have the manual go to the manufacturer's website and view or download it.
Get online and got to www.google.com In the google search box type: "Zonet Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals. The manual will tell you the ip address and it will give you the default user id and password to get into the router.
Jun 02, 2012 | Zonet ZSR1134WE Wireless Router
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do i change the router network password? what is the ip adress??
The internal, LAN-IP address is normally set to a default, private number. Linksys routers, for example, use 192.168.1.1 for their internal IP address. D-Link and Netgear routers typically use 192.168.0.1. Some US Robotics routers use 192.168.123.254, and some SMC routers use 192.168.2.1. No matter the brand of router, its default internal IP address should be provided in documentation. Administrators often have the option to change this IP address during router setup. In any case, however, the private LAN-IP address remains fixed once set. It can be viewed from the router's administrative console.
The external, WAN-IP address of the router is set when the router connects to the Internet service provider. This address can also be viewed on the router's administrative console. Alternatively, the WAN-IP address can be found by visiting a Web-based IP address lookup service like http://checkip.dyndns.org/ from any computer on the home LAN.
Another way to identify the public IP addresses of routers, involves executing a ping or traceroute command. From inside a home network, the (DOS) command "ping -r 1" will send a message through the home router that will cause its IP address to be displayed. For example, "ping -r 1 www.yahoo.com" should result in a message like the following displayed on the command prompt:
To change router password Open your Internet browser, type the address of the router into the URL address bar, and open it. The address is typically in the form of 192.168.X.X. This is the local network address. Enter the account name and password to open the router setup utility. Navigate through the setup utility until you find the screen that will let you change the password. You will need to enter the old password to change it. Decide on a new password that has good security to a hacker. The best password is more than 8 characters and uses both lower case and upper case letters and numbers. Some will allow you to use special characters also. Do not make the password anything that can be found in a dictionary or any date of significance. Enter the old password in the change password page of the router. When prompted then enter the new password. You will be asked to enter it twice to confirm that the correct password is entered. Immediately, record the new password in some secure location that you can find if you forget it. Confirm the password change on the router page and log off the router. To check the information and that the router has been setup correctly with the new password, open the router address in the browser again and login with the new information. If you are able to login, you have successfully changed the password. Network: Router Ssl Vpn
Dec 25, 2010 | AudioCodes Computers & Internet
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Step 2:
Step 3:
If you forgot the router's IP address you can:
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
How di i log into this router?
point your browser to -> 192.168.10.1
default user and pass is:
user: guest
pass: guest
Feb 02, 2010 | Zonet ZSR0104CP (zsr0104cp) Router
Whats the ip address of the main page of the router
Click start and click on run and type cmd.
Black window opens up.
type ipconfig and press enter .
You can see the following listed
IP address , subnet mask and then default gateway. Default gateway is your Routers IP address.
May 18, 2009 | Zonet (ZSR0104UP) Router
I cant lock my wireless router.
Ok, to put a WEP key from our router. You need to configure it, by doing that you need ethernet cable (cat 5). You need to connect your pc to your router using cat5 cable. After you've done that, open your internet explorer/firefox ect., and enter your router's ip address (router ip address can be found in manual or at the back of your router). You will be ask for username and password, just key in if you have one, otherwise just enter the default (mostly, username:admin ; password: none/blank ; depends on manufacturer). After you've done that, go to SETUP menu, and go to Wireless setup you can enable WEP key there, just choose your options. Just try it, I hope it helps you.
Jan 10, 2009 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Zonet ZFS3008 (ZFS3008-04) Logo
399 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
