Question about Microsoft Windows 8.1 64-Bit - System Builder OEM - Windows
Windows script host virus fiber.js
Pop up box C:\program data\{46cdae0e-164f-7f88-ac79=0f0a774bdc84}1.9.3.1\fiber.js".
  • 35 Answers
This looks like a java run-time virus. I would get malware-bytes anti-malware. I'm not saying I'm encouraging piracy but I would try and find a copy of malware-bytes on a torrent site so that you can obtain premium to unlock the real-time protection.
Posted on May 03, 2015
C:\PROGRAMDATA\{BEFF563C-EE7D-87BA-5FFB-F7388F7924B63\1.17.3.1\fiber.js
Jerome; try windows restore, try going back to an earlier date when system worked OK, then as you add stuff , watch and see
what gives the problem.
press the helpful button
Recovery options in Windows 10 Windows Help
Jan 25, 2016 | Toshiba Computers & Internet
Tip
How to Encode your VBS and JS files for secure website uploading
If you are still at Service Pack 2 then you can use Microsoft's own Script Encoder download it from HERE it's a command line version so after you have installed it you need to run the command prompt also make sure the Windows Scripting Host is started.
REMEMBER MAKE YOUR SCRIPTS "FOR YOUR EYES ONLY"
For both Visual Basic Scripts and JavaScript you will need to format the text in your script to look like this;
Replace your code goes here with your actual code when the encoder has been run then you will see that the <SCRIPT LANGUAGE= ********> will have changed to <SCRIPT LANGUAGE= ********.encode> and your code will be random characters.
The Syntax for the encoder from the command prompt is;
Recognized file extensions are .js and .vbs, which are changed to .jse and .vbe, respectively, after encoding, also these type of files can be decoded if you know what you are doing and therefore not totally hacker proof.
IF YOU HAVE SERVICE PACK 3 installed then this won't work at all so the best method is to use this VBS2EXE this is also a command prompt program you must make sure that the script that you want to convert is in the same root folder.
When finished there will be a new file about 10 times larger then the script with the EXE file extension if you try to edit it all the code appears random this is the best method for encoding your scripts
If you want to do it ALL online and feel secure then you can do both VBS (VIsual Basic Script) and (JS) JavaScript using this website below but it is limited to 10kb per file
http://www.f2ko.de/ov2e/ov2e.html
If you create alot of batch files then I suggest that you also check out their BAT2EXE v1.5 this will convert CMD or BAT files into EXE files for web distribution you can also password protect and add a decompiler if required
on May 30, 2010 | Microsoft Windows XP Professional SP2
Script: chrome://wrc/content/common/libs/jquery-1.5.2.js:3589
Script errors are common. The best thing to do is to go to the internet options and deselect the entry that says "warn me of script errors".
Though the errors will still be there you won't get the notice!
Jul 30, 2014 | Google Chrome
So how can I restore my v b script host on my netbook with windows 7 ?
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
Jan 15, 2013 | MSI Ge620-021us 15.6in Hd 1080 Led...
Fix my vb script engine on my computer / Windows 7
Jan 15, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Have a link script gone crazy help plz.
Good Day!
Please renew your Facebook password immediately.
Your account is spamming.
If Facebook found about it, they will disable your account.
You may refer from this link for helpful information
http://facebookerrors.blogspot.com/2011/12/my-facebook-account-is-hacked-what-to.html
Jan 13, 2012 | Facebook Social Network
Internet Explorer script error do you want to continue running scripts on this page? Library not registered
it could be possible that The author of the webpage you are accessing has simply made some sort of programming error and this is typically the most common reason.or that You are possibly running a pop-up killer of some kind which closes the pop-up too quickly which causes the script of the website to fail and thus giving you the error because it didnt complete.
possible You (still) have some sort of spyware or adware infection that tries to launch something such as a popup but causes script errors.
this is the most likely issue in your situation.
Solution:
1. Make sure your Anti-Virus software is up-to-date and then run a full system scan.
2. Try running a scan with other malware detection software. (Malwarebytes )
3. Be sure your are not running Rogue Anti-Virus software ( Security Center, Anti-Virus 2009, and Anti-Virus 2010).
4. Take a look into the Event Viewer to see the path of where the script is coming from. Some more detail may show up in the Event Viewer log)
5. Run windows updates and install any critical/important updates.
hope this helps
Oct 01, 2009 | Microsoft Windows Vista Home Premium with...
When i try to open any drive or any other application a dialog box 'open with' appears why this happens ,how do i solve this problem?
This is problem with registry, there is some sort of corrupt data in your registry which can be cleaned by registry repair.
By the way you can open your drive by using explorer drop down address bar.
Sep 11, 2009 | HP 435768-001 - Compaq Presario C300...
How i install js script software
Java-script is a scripting language interpreted by you browser and is not installed on you PC like compiled software. Java, which is a programming language is installed by downloading JRE for www.sun.com.
If you browser is not running Java-script while viewing web-page, (eg: youtube) that is in you browser options, you probably need to enable JS in you settings. google "enable javascript YourBrowserGoesHere".
Mar 05, 2009 | Microsoft Windows Vista Ultimate Edition
Windows script host settings
first try windows update
if that don't work right down exactly what script it is then
click start then run type in msconfig
then a box will appear click on startup
then find the program click to remove restart computer then click don't show message again
Jan 16, 2009 | Computers & Internet
Microsoft Windows 8.1 64-Bit - System Builder OEM - Windows Logo
260 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
