Question about Tools & Hardware - Others
I have removed all the screws but cannot separate the two halves. What else must I do to disassemble this?
    Master:
  • 456 Answers
Make sure all screws are out first. the 2 halves are held together with clips. they will be hard to pull apart. try and make a small opening with a knife between the 2 halves and work around untill you come across a clip, push down on the clip to release it . there will be a few holding them together and you might find if you unclip one and move on it will clip back into place so a few thin instruments will be needed all the way around
Posted on May 01, 2015
The electrical connection 0n Rowenta steam iron DG5030 is inconsistent. I wish to disassemble and check the tightness of connection
Screws may hold the shell together but the halves are usually clipped together by hooks around the edge of the shell to discourage would be 'electricians' from doing home repairs. Once you've removed the screws and the body held by the screws doesn't come apart, look for a point where you can insert a screw driver in it to pry the body part out. If you can't do that, then don't do it. best thing to do is take it to a repair agent. At least it's safer.
Dec 28, 2014 | Rowenta Irons
How to do you disassemble a Shark S3601CO Steam Mop?.
it's glued together. It's not made to repair. Throw it away and don't buy another Shark product. They are disposable.
Jul 13, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hy108tgt
Our HY-108 (not a HY-108TGT) does not have a filter when it was purchased new from a Retailer.
IMHO, Honeywell/KAZ designed these Tower Fans to be disposable if they fail to work or need cleaning.
These Fans are hard to disassemble for service or maintenance, OEM replacement Parts are unavailable to the general public, service documentation is hard to find, and the Tower Fans tend to have a short Product lifespan. THEY BREAK EASILY! The OEM Service Manual points to replacing complete parts assemblies because few electronics diagnostics and no schematics are provided.
The HY-108 case can start to be disassembled (I have done so on ours) by *First* removing the screws and separating/removing the plastic Base from the main Case assembly. *Second* remove the Phillips-Head screws on the back of the Case. *Third*, the internal plastic 6 Tabs that keep the 2 halves held together need to be gently separated - careful, they break easily. You need to gently loosen the internal plastic "Tabs" by using a thin flat-head screwdriver to gently and carefully separate the outer shell cover.
Apr 19, 2014 | Honeywell Dryers
How to disassemble logitech mx-1100
Pull off the 2 largers slide plate stickers on the bottom. you will find 2 screws on the nose end and one on the bottom end of the mouse.. the 4th screw is located under the sticker in the battery tray lining. remove this sticker and remove the 4th screw. now you can separate the 2 halves but be careful for the ribbon cable connecting the 2.
Mar 31, 2012 | Logitech MX1100 LASER Mouse
Battery on my Tom Tom XXL540S is dead. How do I replace it. I can see no way to disassemble the unit.
Remove the two #5 torx screws under the label, using a butter knife or similar and starting near the screw hole side, slide the knife under the front bezel and pop it off the back. Push small white connector clamp towards ribbon cable on back half and the cable will slide out. The two halves are now separated. Remove three screws and remove circuit board. Wiggle and pull out the battery connector. Slide butter knife under battery and pry loose from the sticky tape.
Voids any warranty!
Mar 08, 2011 | Tomtom XXL 540S GPS Receiver
My Porter Cable 4x24 VS belt sander has clogged up and I cannot get it unclogged. I've tried to disassemble it to get at the sanding dust channels but have had no luck at separating the two halves of the...
did you remove the screws that are under the handle halves, and before I completely disassemble the tool do you have a shop vacuum and if so remove the dust bag and put the hose on that outlet and run the tool and see if it pulls anything out. I would only split the halves as a last resort. Let me know if you need more assistance.
Feb 19, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
Hi, I need help disassembling my weedeater blowervac.
it seems silly but the decal thats below the handle is tough, cut it with a knife. There are no studs to the block,look in all the little holes for a hidden screw, they all go in thru the same side
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Cannot disassemble Milwaukee 6016 to replace brushes
exactly what screws did you remove. you have to remove the bottom platen first (pad) then remove the housing screws. you need to remove the fan also and then might need to apply some pressure to split the housing halves.
Mar 03, 2009 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
Ryobi rs-45 sander will not run
If you can not separate the case you missed a screw somewhere, happened to me many times, look closer there is another one, they have a way to hide one on you
Feb 27, 2009 | Tools & Hardware - Others
HOW TO REPLACE HEADLIGHTS ON 2000 CHRYSLER LHS
ATTN: NIKKICARROLL
here is how to replace the bulb in your vehicle
  1. Release the hood latch and open the hood.
  2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp.
  3. Remove the screws holding the headlamp module halves together.
  4. Separate the module halves.
  5. Disengage the wiring from the headlamp bulb.
  6. Remove the retaining ring from the back of the headlamp bulb.
  7. Pull the bulb from the lamp.
To install:
  1. Push the bulb into the lamp.
  2. Install the retaining ring to hold the bulb in the lamp.
  3. Engage the wire connector to the back of the headlamp bulb.
  4. Place the module into position on the vehicle.
  5. Install the screws to hold the module to the vehicle.
  6. Install the radiator closure panel sight shield.
  7. Check the headlamp alignment and operation.
88176gb1.gif Exploded view of the fog lamp with the bulb removed
Click to Enlarge
  2. Remove the radiator closure panel sight shield as needed to gain access to the headlamps.
  4. Separate the halves.
  5. Remove the fog lamp wire connector cover.
  6. Disconnect the wires from the fog lamp bulb.
  7. Disengage the retainer clip holding the bulb to the fog lamp.
  8. Remove the bulb from the fog lamp.
To install:
  1. Place the bulb into position in the fog lamp.
  2. Engage the retainer clip to hold the bulb to the fog lamp assembly.
  3. Attach the wire connectors to the fog lamp bulb.
  4. Install the fog lamp wires connector cover.
  5. Place the module halves together.
  6. Install the screws to hold the headlamp module halves together.
  7. Install the radiator closure panel sight shield.
  8. Verify the fog lamp operation and alignment
ATTN: WDSNEED1
Removal & Installation 88176g87.gif Remove the screws retaining the headlamp module to the mount adapter
Click to Enlarge
  2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp fasteners.
  3. Remove the screws holding the headlamp module to the mount adapter.
  4. Separate the headlamp module from the mount adapter.
  5. Disengage the wiring from the headlamp and foglamp.
  6. Remove the headlamp from the vehicle.
To install:
  1. Attach the wires to the headlamp and foglamp assembly.
  2. Place the headlamp module into position on the mount adapter.
  3. Install the screws to hold the headlamp module to the mount adapter.
  4. Install the radiator closure panel sight shield.
  5. Check the headlamp alignment and operation.
Jul 28, 2008 | 1994 Chrysler New Yorker
Tools & Hardware - Others Logo
95 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
