Question about Olympus VG-170 Digital Camera - Jap/Eng Black
The monitor picture has a purple cover all over the picture
And the picture is out of focus
    New Friend:
I have this problem... reset all settings not working...
the monitor picture has a purple cover all over th - monitor-picture-purple-cover-all-over-dpu0oangiqh3vuyvxa4zfmvi-4-0.jpg
Posted on Dec 24, 2015
    Master:
  • Olympus Master
  • 996 Answers
Reset all settings
Posted on May 02, 2015
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
CRT monitor screen is out of focus.text and other images looks blurry
This kind of symptoms can be correct by the focus adjustment at the flyback transformer. FBT mostly has two control knob (Focus and Screen), focus is usually at the top one like in the sample picture below.
Open the back cover of your unit and then locate the FBT. Power on the unit and try to adjust the focus knob.
If the symptoms can't be cured by the this step, this is an indication that the CRT socket is already faulty. You have to replaced this parts and then make some adjustment at the focus knob of the FBT and your unit will back to normal again.
CRT(picture tube) socket
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 14, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Nothing displays on the LCD monitor
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
May 29, 2010 | Canon PowerShot A75 Digital Camera
My c180 shots turn purple while focusing or
I am guessing here that you are talking about the results in the LCD screen, how do the pictures look when downloaded to the computer.
Apr 04, 2010 | Kodak EasyShare C180 Digital Camera
The monitor on my Dell 4400 computer is too dark to work with. I have tried incresing the brightness by using the funtion up arrow. Any suggestion?
hello ! tackle this problem is that you must open the cover of the back of the monitor go adjust the focus control nob flyback ie picture tranformer beacuse its out of focus
Jul 13, 2009 | Computers & Internet
LCD Dell Monitor displaying purple and green rather then picture.
sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
Jul 11, 2009 | Dell E177FP LCD Monitor
Purple/Green Outline surrounding picture
I have seen two different things cause this. The first and most common is the electrical failure of one or both convergence IC's. A handful of times, the data in the DCU became corrupted and I was able to enter the service mode, go to manual convergence and correct the one location that was off.
Apr 28, 2009 | Toshiba 50HDX82 50" Rear Projection...
Unclear images
Remove the rear cover and adjust the focus control on the flyback. Use a non-conductive probe, available as adjustment tools from any radio shack. On the FBT (Flyback Transformer) you have two protruding adjustments - one marked screen, the other focus. The screen adjustment increases the G2 voltage to the crt and brightens the picture by increasing the voltage exponentially. You don't want to adjust the screen voltage. The other is the focus, you can easily turn that clockwise or counter clockwise and watch the screen to set it at your preference.
Hope this helps.
Bill
Nov 11, 2007 | E-Machines 17F2 17" CRT Monitor
Hitachi 53SDX89BA Projection TV
CRT lenses need to be aligned. Would recommend having a profesional technician do it. Easy fix for a CRT profesional but quite technical for the homeowner. Before fixing it, unplug. open up back go in and look at the front of the tubes with a bright flash light. If you see a brown square under the lenses you might just want to upgrade instead of fix. Brown square is CRT burn.
Oct 27, 2007 | JVC PD-42WV74 42 in. Plasma EDTV
Can't take picture with monitor off?
When the LCD display is "off" the focus mode is automatically switched to "Single AF" mode (since there is no way for the user to confirm that the proper subject is focused) and unless focus is locked the camera cannot fire. When the camera is in "Continuous AF" Focus mode the camera will take a picture whenever the shutter release button is pressed, wether or not the subject is in focus. You can take a photo with the monitor off, but the camera will have to lock focus before it can fire and will not respond as quickly as with the monitor on.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Olympus VG-170 Digital Camera - Jap/Eng Black Logo
102 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
