Question about Drills
I need a charger for JDB 180 18V battery - Drills
    Top Expert:
  • Drills Master
  • 49,269 Answers
There are chargers on the market that charge a multitude of 18 volt battery shapes so there will be a charger for your battery
try battery shops of shops that sell a variety of 18 vole user equipment
Posted on May 02, 2015
2000 impala code p0140
02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
Read more at: http://www.obd-codes.com/p0140
Copyright OBD-Codes.com
Best Regards,
JDB
Jul 24, 2014 | 2000 Chevrolet Impala
What is wrong when the high beam lights doesnt go off? i have to disconnet the battery so that its not drained
While this will not "fix" the problem, it may alleviate you having to disconnect the battery. Once you have turned of the car, use the headlamp switch to the left of the steering wheel to turn on the lights manually. Then push the switch back in, and the lights will turn off. If the high beams will not turn off, it is possible that your multi-function switch has gone bad. This is a costly repair, and should be properly diagnosed by a certified service professional prior to replacement of the switch.
Best Regards,
JDB
Jul 17, 2011 | 2000 Chevrolet Impala
Adjust door tension on jdb-5 jenn air dishwasher, door too heavy
There are springs on both sides of the door, likely one has snapped. You can get at the spring without removing the machine, sometimes, by pulling the bottom panels...
Jul 02, 2011 | Dishwashers
How do I get the outdoor temperature to work on my Sharp Atomic clock, have replaced batteries in both clock and transmitter and reset numerous times
Hello jdb..... The outdoor transmitter needs to undergo a wee bit of maintenance. Remove those new batteries and clean the battery contacts with the eraser on the end of a common pencil. Then replace the batteries. IF you notice that the batteries slide in easily, use a small flat blade screwdriver to gently lift the battery contacts to increase the contact when you do slide the new batteries in. Joe
Thanks for choosing Fixya!
Dec 19, 2010 | Baby Gear
Dishwasher displaying L# what do I do??
press start and light will not come on and start
jenn-air dishwasher jdb-5
Nov 14, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
Replacement Battery
I found a 18V Powerglide battery at AceHardware.com and they say that it will fit ANY 18V Powerglide tool. Their part number is 2103992 and list price is 23.99. However I would strongly recommend that you look at the battery online to make sure it will match up. This is allthe information I can find. Good Luck
Dec 31, 2008 | Ace Hardware PowerGlide 18V Trigger...
Jenn-air JDB-2100aws dishwasher not drying properly
1. If you do not use Jet-dry liquid in detergent dispenser left side compartment, the drying result for dishes will be very poor.
2. You should check the heating element for continuity(conections for heating element under bottom panel of d/w).
Dec 15, 2008 | Jenn-Air Dishwashers
Door doesn't want to open on my Jennair JDB 1080 dishwasher. Gets stuck, like the latch doesn't spring open. What can I do to it?
The handle is broken. You may have to force the door open so you can work on replacing the handle.
Nov 24, 2008 | Jenn-Air Dishwashers
Drills Logo
272 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
