Question about Toshiba Satellite Computers & Internet
Water dropped on my Toshiba laptop,and i removed a battery,what should i do next please help
I tried to remove a battery but before that i tried to switch it on,it failed
    Scholar:
  • 190 Answers
If you don't know how to remove the keyboard then I would suggest you run a blow dryer along the top keyboard but not too hot. Aim the dryer straight down and not on an angle because this might push water along into other areas. Do this every 15 minutes or so then leave it alone over night. Put the battery in and try booting it up. You can go on youtube to see videos of how to remove a keyboard on your model which is a better way to check for water.
Posted on May 01, 2015
  • Toshiba Master
  • 5,631 Answers
Probably you burned it out when you tried to swith it on
Put it in some rice, let it dry for some days and then try to turn it on. If won't turn on, pray and take it for repair.
How do i remove the cd dvd drive
Turn off the Toshiba laptop, remove the AC adapter and any other peripheral devices, and close the lid.
Turn the laptop over.
Touch an unpainted metal surface to discharge any static electricity. Release the battery lock-usually located near the back of the laptop-and remove the battery from its bay.
Remove the screw holding the DVD drive in place.
Where the screw is located depends on your Toshiba's model, but in newer laptops-particularly the Satellite-the screw is located next to the Toshiba sticker.
Unlike the other screws, which are embedded into the laptop, the DVD screw is even with the rest of the laptop's surface.
Gently pull the DVD drive from its bay to remove it from the laptop
hope this helps
Sep 13, 2012 | Toshiba Satellite P505D-S8935 Notebook
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Drop off a glass of water on my toshiba laptop keyboard
You must have removed the battery immediately so that the water will not seep through and short the internal circuits. If this had happened thenthe motherboard would be faulty . What could be done is to remove the keyboard and the motherboard and fully dry the board , keep aside and heat slightly using a hair dryer.Assemble after several attempts to warm off moisture and reset. if the PC does not boot, then it is best to seek consensus and estimation. Do not replace any part on a suspicion.
Dec 14, 2011 | Toshiba Satellite M35X-S163 Notebook
Water was poured on the keyboard. Battery was removed immediately and wiped dry as was the keyboard. Keyboard was placed under the fan upside down for approximately 2hrs after which battery was replaced...
First thing is to not try powering the laptop on after the water fell on it. Next, you should remove the battery off the laptop immediately. When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of water on the circuit boards & on other components. On circuit boards, water damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no water seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the water fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Aug 25, 2010 | Sylvania Meso GNET28001SO Notebook
Toshiba Satellite A55-s1066 need help Loacting Bios Chip.
you need to remove all at same time and memory modules too, and after remove the cmos battery, try to find a passw clear switch on the motherboard nearby cmos battery.
Feb 14, 2010 | Toshiba Satellite A55-S1066 Notebook
Toshiba a200 flashing power light .. blue blue red red HELPPPPPPP
Remove battery and power
Remove memory in lower socket, the one on the system board and try reboot with just power cord. May have bad socket
Dec 11, 2009 | Toshiba Satellite A200-0ET00X Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Toshiba M35X-S109 Doesnt Start
you may have a faulty motherboard connection, but try connecting the power adapter in without the battery and see if it runs, then replace the battery back in the compartment.
Oct 15, 2007 | Toshiba Satellite M35X-S109 Notebook
A105 dvd rw removal
Let me suggest you one thing.When you don't know please don't try(i screwed my laptop in the same way)Take it to the nearest service center.LOcate it by clicking the link below.. http://pcrepair.toshiba.com/
Oct 08, 2007 | Toshiba Satellite A105 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
