Question about APC Computers & Internet
Why won't the new battery allow the xs go on line
Xs 1000 will not go on line after replacing batteries
  • Ricky Haycraft
    Ricky Haycraft May 04, 2015
    Dead battery in logic control board or improper start up
  • Ricky Haycraft
    OR perhaps the new battery is DEAD?
SOURCE: Overload on ADP Back-UPS XS 900 with trivial load
Replace 24v dc small fan, it does not work!
You can buy a new one here
https://www.alliedelec.com/Search/ProductDetail.aspx?SKU=5920640&MPN=OD4010-24MB&R=5920640&SEARCH=5920640&DESC=OD4010-24MB
Posted on May 04, 2009
  • 5 Answers
SOURCE: apc xs 1500 overloads even with nothing plugged
Plz check MOSFET which working in inverter section.
Posted on May 12, 2009
JaxPlanet
  • 922 Answers
SOURCE: APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Posted on Aug 18, 2009
pravinbhavsa
  • 348 Answers
SOURCE: hace a APC XS 900 that said battery needs
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Posted on Mar 14, 2010
Testimonial: "There is no way to check the water in the batteries as thry are sealed. I found out that after a load is applied it goes on battery for a few seconds "
  • 35 Answers
SOURCE: the battery on my 1300 xs keeps saying
Check your wiring make sure the clip has not come on done and its staggering connection. I have the exact same make/model had the same problem it was the clip. Also, if that doesnt work remove the battery and have it tested for bad cells. If you need further help IM me on AIM @ candidate4death.
Cory
Posted on Jul 26, 2010
APC UPS XS 1500 exploded after installing battery
batteries were put in wrong. Nothing else it could be. Most likely is was your DC capacitors blowing up.
Feb 19, 2015 | APC Back-UPS XS 1500 - UPS - 865 Watt -...
Where do I find the memory battery in my Canon Rebel XS digital
As far as I know, the backup battery is not user-replaceable. You may need to take the camera to a repair shop for replacement of that battery.
http://static.highspeedbackbone.net/pdf/canon_eos_rebelxs_manual.pdf
Mar 26, 2013 | Canon EOS Rebel XS 35mm SLR Camera
Canon eos rebel xs 1000d will not take pictures. changed battery, changed sd card. has red steady light.
The XS has a history of defective main circuits and this sounds like that.
It will have to go to Canon as it requires software to replace and only Canon has it
Oct 29, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Battery signal flashing
in some UPS model, battery flashing is just an indication that the batteries are not fully charged. there is problem is the flashing LED is red in colour
Jun 23, 2012 | APC BX 1000 Back-UPS XS 1000 (APNBX1000)...
My Apc xs 1300 keeps chirping. This happened after a power outage in our building. is the battery fried?
Replace the batteries. This will fix the problem. Call me at Gruber Power Services for Free tech. support. 800-658-5883 x256 ask for Eric
Aug 22, 2011 | APC BACK-UPS XS 1300VA LCD 120V...
My canon EOS 1000 rebel XS wont turn on... its brand new
Brand new?...take it back. New cameras aren't supposed to give you trouble.
Aug 19, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
1980 Yamaha XS 650 special not charging
check the rotor magnet to see if the windings are shorted to the base use an ohm meter to check for grounding to the base.
Apr 04, 2010 | 1980 Yamaha XS 650 G
Canon rebel xs Battery and error 99 problems
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel XS error 99
Instead of taking out the battery, just open and close the battery compartment to reset the camera.
SVRGuy02 is right, set the slep time longer to avoid the issue so much and just open and close the battery compartment before beginning each shooting exercise
May 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Computers & Internet Logo
183 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
