Question about Sears 208cc Dual Rotating Rear Tine Tiller, 49 states only
Need to replace the pull rope assy. where can i buy complete pull rope assy
    Top Expert:
  • Sears Master
  • 45,468 Answers
Any accredited mower shop will have the assembly for your unit better if you can find a service agent for your engine.
Posted on May 02, 2015
Pull start assembly came apart
I assume you have a lawn mower & posted the
question in the wrong place
Need to go to power equipment store with the
top motor cover & rewind assy & buy a new one
Jun 20, 2012 | Cars & Trucks
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
How do I repair the pull cord on a masport 600 mower - the cord snapped when I was trying to start it.
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assy. Depending on engine model you may hae to remove the air shroud with the recoil.
- Remove the broken rope assy from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rop burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end of the trheaded through rope.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assy.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Briggs & Stratton Briggs Stratton...
How do I fix/replace the starter rope on a TB20CS (Tuffy Troy Bilt String Trimmer) that's broken? Do I need any special tools?
Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Troy Garden
How to replace pull cord on ryobi 725r trimmer?
Before you start... transfer the handle assy to the new rope. Remove the old rope and install the new rope just like the old one. Make sure to tie 1 knot in the end of the rope so that the rope ded not pull out of the handle
-Remove the recoil assy.
-Remove the old rope.
-Wind the spool counter clockwise until it stops
-Back up the spool until the rope hole aligns with the rope guide. DO NOT let the spool unwind. It really takes 2 people to do this.
-Burn the end of the new rope with a match and very quickly while it is still soft. pinch the end of the rope to make it as small as possible.
-Thread the new rope through the rope guide and into the hole for the knot of the spool.
-Use a scribe or needle to lift and pull the new rope through the hole
-Tie 1 knot in the rope
-Pull the knot into the hole in the spool
-Let go of the spool and the rope will rewind
-Install recoil assy
-RETURN TO SERVICE
Thanks for using FixYa!
Kelly
May 09, 2010 | Garden
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
The starter pull cord has pulled off.
EASY,REMOVE TOP COVER OF ENGINE THAT HOUSES ROPE ASSY. LOOK UNDERNEATH PLASTIC PIECE,CUT THE KNOT OFF THAT COMES THROUGH HOLE AND PULL AND EXISTANT ROPE OUT. OK, GET NEW ROPE AND HANDLE TOGETHER,THE END THAT IS OPPOSITE FROM NEW PULL STRING HANDLE YOU ARE GOING TO USE. CAREFULLY WIND UP ROPE HOUSING NICE AND FIRM JUST BY WINDING IT UP WITH HAND IN AS IT SITS IN TOP COVER. WHEN YOU THINK IT HAS ENOUGH TO PULL ROPE IN FEED END OF ROPE IN HOLE AND IN CHANNEL OF ROPE HOUSING,THERE IS A SMALL HOLE TO LINE IT UP WITH,WHEN SEE THE ROPE END FEED IT THROUGH THAT HOLE NOW. MAKE TAKE ANOTHER SET OF HANDS OR A WEDGE TO STOP RETRACTING OF SPRING. PULL ROPE THROUGH AND TIE A DOUBLE KNOT AT END SO IT WONT PULL THROUGH. SLOWLY LET IT PULL ROPE IN,THEN PULL ROPE BY HANDLE FULL LENGTH TO ENSURE ALL KINKS ARE OUT AND IT PULLS BACK IN LIKE IT SHOULD.
Jul 12, 2009 | Toro Lawn Mower With Toro Power Tools
The rope broke on my lawn mower and I am trying to rewind the spring, but was advised to buy a complete starter assembly, I need to know how much one is and where can I get one. I bought my lawn mower from...
If your rope broke, there was no reason to take the spring out. The rope can be replaced just by taking the rewind housing off, turning pulley to get rest of old rope out, wind the pulley (and spring) the direction the rope would be pull it when starting. Then , when it's wound tight, back off to align the holes in pulley and cover. Hold it there, stick about an 8' piece of rope from the outside through the pulley and tie a knot. Hold the rope and let the spring pull the rope back into the starter. an tie handle back. Take your housing, and spring to a shop. They can re-install the spring and put on a rope a heck of a lot cheaper that buying that whole assembly.
Jun 16, 2009 | Mtd 22" Yard Machine Push Mower
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Sears 208cc Dual Rotating Rear Tine Tiller, 49 states only Logo
74 people viewed this question
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
