Question about Craftsman Garden
My front wheels wont line up - Craftsman Garden
    New Friend:
    Problem Solver:
  • 10 Answers
Try a hammer
Posted on Sep 20, 2015
All wheel drive dont work
there is an actuator in the front axle that engages the drive shaft to the wheels. there is also a vacuum actuator i believe in that model it is under the battery plate. if you put on lift you can trace the cable from the front axle back to the actuator and check the cable, actuator and vacuum lines. Gm's system is complex and when is messes up its a night mare. but common failures are actuator cracked or broken vacuum line.
Jan 11, 2014 | 2004 Buick Rainier
Front wheel wont turn when you tighten up main bolt on my KTM 200 EGS
you will need to check the wheel bearings, and the internal spacer between them, the speedo drive can also cause this if the tabs are not lined up with the wheel
Jan 28, 2011 | KTM SX 200 Motorcycles
I have a ford f 150,v8 engine and my 4 wheel drive wont work now, can it be just a fuse?
Is the system ESOF ( Electronic Shift On the Fly ) or MSOF ( Mechanical Shift On the Fly ) ?
Lift and support the front of the truck so the front wheels are off the ground ( take safety precautions, chock wheels, jack stands, etc )
Key on, engage 4x4 and try to turn the front drive shaft.
If it turns it is a problem with the transfer case.
If it doesn't it is a front axle engagement problem.
I would suspect that the front drive shaft does not turn, and the issue is with the vacuum lines for the front axle.
You can check the vacuum lines with the engine running, and have a vacuum gauge on the front disconnect motor. Pink line is 2WD operation ( unlocks the front axle ) Light Blue is the 4WD operation ( locks the axle ).
The disconnect motor is on the front axle, item #10 in the picture below
Picture of it.
Dec 10, 2010 | 1998 Ford F150 Regular Cab
My 2001 ford supercrew wont engage into 4 wheel drive
If the front axle does not turn, the cause generally has to do with the Vacuum disconnect motor on the axle ( Item #10 in this picture ) :
Close Up :
The vacuum disconnect motor is operated by the vacuum axle disconnect solenoids on the firewall
You can test from here with a vacuum pump ( i.e. mightvac ) to see if the vacuum lines to the vacuum disconnect motor are good.
The pink vacuum line is 2WD operation, the Light Blue vacuum line is 4WD operation.
If the vacuum lines test good from here to the disconnect motor, and applying vacuum locks the front axle, it is either the vacuum solenoids, or the vacuum reservoir behind the battery, or the vacuum lines to the solenoids.
The solenoids have + VDC all the time, and the GEM applies ground to the correct solenoid to engage or disengage the front axle.
Nov 06, 2010 | 2001 Ford F150 Styleside SuperCrew
4 wheel drive wont engage on kia sportage 2001
there are vacum line one on each side behide the wheels see if they are broke or leaking i had the same problem
Feb 10, 2010 | 2000 Kia Sportage
4 wheel wont work have 3 vac line gone on pas side where do they go 85 dodge ramcharger auto
The lines connect to the toggle switch, and run down to the transfer case.
Feb 03, 2010 | 1985 Dodge Ramcharger
Four wheel drive wont engage. Tranfer case is
Sounds like you either have a vaccum leak or your 4 wheel drive actuator is not working to engage the front differential.On my 98 ram there is a black and red plastic lines that are used for the vaccum lines. They are underneath and go from the transfer case to the front axle, check to see if one or both might be cracked or broke completely.If the lines are good then it could be your actuator on the front axle. A new one is about $93 at advance auto parts and not very hard to replace
Dec 15, 2009 | 1998 Dodge Ram 1500 4WD
Cant remove wheel hub
here is procedure
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual
REMOVAL AND INSTALLATION Wheel Hub Bolt Removal
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly. Refer to Section 04-04 .
  1. Remove disc brake caliper (2B120), and front disc brake rotor (1125). Refer to Section 06-03 .
Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478). Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120), front disc brake rotor shield (2K004) or front wheel knuckle (3K185).
  1. Remove rear brake pin retainers (2N386). ( I think it is a T 40 torx bit you need)
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125). Do not pry directly against metal caliper piston or damage will occur.
  1. Position disc brake caliper out of the way and support with wire to avoid damaging the disc brake caliper and front brake hose (2078).
  1. Remove outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate.
  1. Remove inner brake shoe and lining assembly.
  1. Position lug bolt (1107) to clear front wheel knuckle (3K185).
  1. Remove lug bolt from wheel hub (1104).
Installation
  1. Install lug bolt into wheel hub.
  1. Using a lug nut (1012), seat wheel hub bolt into wheel hub.
  1. Install front disc brake rotor and disc brake caliper. Refer to Section 06-03 .
  1. Install wheel and tire assembly. Tighten lug nut to 115-142Nm (85-104 lb-ft).
May 25, 2009 | 1996 Mercury Sable
2001 Kia Sportage 4 Wheel Drive Wont Engage
fuses relays in engine compartment or in dash board . look at transfer case look for vacuum lines or electric lines.its probably electric. because most 4 wheel drive uses electric motors.99 up to 2009s model.
Mar 02, 2009 | 1999 Kia Sportage
New brakes
Still have air inside, because you used gravity feed method.
Jul 17, 2008 | 2000 Chrysler Cirrus
Garden Logo
47 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
