Question about Garden
Running fine 2 days ago. yesterday started running rough, kinds like it was out of balance.
Has new oil, oil filter, air filters fuel filter, new plugs. 117 hrs.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Sounds like a misfire, check the plugs and leads are tight. Pull off each plug lead in turn and see if it makes a difference. The one that doesn't is faulty somewhere (plug, lead or ignition coil)
Posted on May 04, 2015
Testimonial: "Thanks I'll try that"
  • 86 Answers
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
Posted on May 09, 2009
  • 3 Answers
SOURCE: craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Posted on Jun 23, 2009
  • 202 Answers
SOURCE: craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Posted on Jul 07, 2009
  • 12 Answers
SOURCE: 17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Posted on Aug 09, 2009
nova2nv
  • 197 Answers
SOURCE: Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
Posted on May 22, 2010
Runs rough
The problem of rough running of vehicle may also arise due to following reason other than you mentioned and they are listed below:
1. Bad gasoline condition
2. Clogged Air Filter
3. Poor fuel filter
4. Discharged battery
5. Low oil in reservoir
Check for the components and solve the issues. Cleaning or replacing the air filter and fuel filter can solve the issue. Charge the battery if it is discharged or replace it with new one if in bad condition. Refill the oil reservoir.
Jun 23, 2013 | 1999 Ford Ranger SuperCab
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
1997 buick hard to start why?
Have the fuel; pump checked for pressure bleed down after sitting, it should hold pressure within 5 PSI of rated running pressure after shutting sown the engine for extended periods.
Sep 02, 2012 | 2002 Hyundai Santa Fe
I just took my ducati out of its winter garage, when i parked the bike there 4 months ago it was all fine, but today when I started it first time this year the engine did not run well. after 30 minutes...
hello rob. often when there is oil in the air filter it is an indication that the machine was turned on it's side. that said, replace the air filter and the spark plug[s]. Also remove any old fuel and replace it with brand new fuel, not fuel that has been sitting around.
finally if it is still rough running go to the auto parts store and get a bottle of a product called seafoam, a fuel additive that cleans the internal parts of the engine remarkably well.
Joe
Apr 29, 2011 | Ducati 900 SS Motorcycles
82 22-R toyota truck automatic runs fine idles fine then for no reason will not idle when stopped. I have to give it gas to keep running but runs rough. New plugs,dist. cap, wires, & rotory button....
I would suggest also replacing all O2 sensors, PCV valve, air filter, fuel filter.. Just might clear it up.. Not expensive and if issue continues - you will have ruled all that out as a cause..
Have a nice day !
Apr 09, 2010 | 1983 Toyota Pickup
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
1999 Buick Regal GSX won't stay running......
It's probably the mass airflow sensor and/or oxygen sensors.
Jun 18, 2009 | 1999 Buick Regal
1993 altima will crank but will not start..
replace the distributor oil is leaking into the electronics of the distributor and shorting out pull cap back off and look and see if oil is leaking out
Jan 24, 2009 | 1993 Nissan Altima
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
