Question about Yard Machines Garden
Blue print for the top pulley - Yard Machines Garden
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Printing printing purple instead of blue
registration error which mean the colors are not laying on top of each other, in this case magenta (red) and Cyan (blue) giving you purple, need to have a tech come out and run regisrtation procedures
Feb 16, 2014 | Konica Minolta bizhub Office Equipment &...
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
My LB 615 is printing just the top part of each character - I have a hunch one of my 'new people' may have accidentally changed a setting on the FLT or other keypad keys. Any suggestions?
The FLT setting would affect character spacing left to right by setting the distance the hammer has to move to get to the platen.
Phasing affects character formation by adjusting the timing of the hammer.
If your characters are missing the tops of all of the characters your band has been moved from the correct tracking on the band pulleys.
Adjsutment is made with the blue lever on the right Idler Pulley, Flip the lever down to release tension and slide the band back to the pulley flanges. LIft the lever and spin the pulleys counterclockwise a few rotations. Make sure the band doesn't "walk" out again as that would indicate a problem you would need tools to fix.
Also make sure the ribbon is tracking properly as that can cause poor character formation.
Dec 21, 2010 | Dataproducts LB-615 Printer
My zebra 140iIII is jerking when it prints. it will print a couple and **** etc. also it is spooling slowly.
Remove the side cover and check for missing teeth on the main drive belt. If you have to replace it start over the lower pulleys first and the top pulley last.
Sep 30, 2010 | Zebra Printer 140-751-00000
Hi There Lexmark E232. Cartridge more than half full, but top blue Led is on, and yellow (second from top)is flashing! Not printing. Can you assist please?
Do a test print directly from the printer, just press the blue lit button.
Look for the Toner AND Photoconductor bar graphs.
The Photoconductor may well be at the end of its life.
Apr 10, 2010 | Lexmark E232 Laser Printer
The washer grinds while washing. This came out of the blue one load its good the next it sounds like its eating its self.
check the pulley on the pump they have a common thing of the pump pulley comming apart and grinding if not fixed it will melt the motor pulley and belt
Dec 31, 2009 | Maytag Atlantis MAV9501E Top Load Washer
Surpentin belt
if you have a car quest their they can show you or print a belt routing pic
Oct 12, 2008 | 2000 Oldsmobile Intrigue
Top of words will not print
The top of the ink cartridge is clogged
Try a colored word red blue yellow
or green and see what happens.
Oct 01, 2008 | HP DeskJet 5740 InkJet Photo Printer
Printing blue on top of pink
There is a common colour problem with this model printer it is caused by the scanner assembly (there's a fan that blows megenta into the scanner unit).
Solution is to clean the scanner mirrors.
Aug 04, 2008 | HP Color LaserJet 2600n Printer
Garden Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
