Dean SM20G2 Deep Fryer
Problem for Dean SM20G2 Deep Fryer
Dean SM35GM pilot light low and burners won't ignite
By jennieb0903 on Jul 10, 2009
I have a Dean SM35GM deep fat fryer and my problem is that the pilot light is so low that the burners won't ignite. I have been trying to find out information on this model but it seems it's quite old and finding information or help seems almost impossible. What could the problem be? I need to have this up and running again as quickly as possible...we are losing a lot of business because we cannot fry anything.
Solution #1
posted on Aug 19, 2009
Not Rated)
KMB001
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #2
posted on Jul 29, 2009
Not Rated)
Capt Rick
Rank: Guru
Rating: 92%, 24 votes
The first thing that you need to check is the gas regulator in between the incoming gas line & the fryer. There is a plastic plug in the top, if this regulator is covered in grease then the regulator is not being vented and you will never get the burners to fire. Next is the gas valve, close to where the pilot tube comes from the valve you will find a screw about the size of a dime or smaller. WITH THE T-STAT TURNED TO THE OFF POSITION Remove that screw cap & down inside there is a plastic adjustment screw, with the unit pilot on, adjust that screw counterclockwise to the desired flame height. You won't need more than a couple of inches, now cycle the t-stat on and the burners should light. If they do not e-mail me at capt_rick1912@yahoo.com & I will walk you thru it.
captrick
Comments:
Jul 29, 2009
- The first thing that you need to check is the gas regulator in between the incoming gas line & the fryer. There is a plastic plug in the top, if this regulator is covered in grease then the regulator is not being vented and you will never get the burners to fire. Next is the gas valve, close to where the pilot tube comes from the valve you will find a screw about the size of a dime or smaller. WITH THE T-STAT TURNED TO THE OFF POSITION Remove that screw cap & down inside there is a plastic adjustment screw, with the unit pilot on, adjust that screw counterclockwise to the desired flame height. You won't need more than a couple of inches, now cycle the t-stat on and the burners should light. If they do not e-mail me at capt_rick1912@yahoo.com & I will walk you thru it.
captrick
Was this helpful?
Yes
No
Popular Solutions for Dean SM20G2 Deep Fryer
Questions and Unsolved Problems for Dean SM20G2 Deep Fryer
Do you recommend Dean SM20G2 Deep Fryer?
Answer
Answer
I purchased a cdf-100 without a manual from Bed Bath & Beyond. It didn't have the manuals... (More)
Answer
Model 168969 handle is broken - where can I get a replacement handle. Thanks
Answer
red light comes in and the temprature starts dropping. we press the reset red light goes away and... (More)
Answer
I took it apart to clean and cannot get the deep tray back in the electrical part
Describe your Deep Fryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Deep Fryer Experts
Top Small Appliance Repairmen
in , PA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
