Question about Powerland PD3G6500E
The generator is new and runs well on gasoline, but does not start with LPG Gas. What could be the problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Carburetor shutoff valve may not be functioning properly wen switching to LPG
Posted on May 25, 2015
Holden statesdman 1994 VR It is on PETROL AND GAS will start on petrol but keeps stalling when switched over to gas is good
I assume this is dual fuel.... LPG and gasoline??????? Is cooling system full? If so, probably plugged filter on LPG convertor. If you are not knowledgeable with LPG, get someone who is. LPG is highly explosive.
Aug 21, 2017 | Kia Cars & Trucks
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
My Mitsubishi Magna 2005 won't run on lpg gas what's causing this
check selector valve, check if gas is reaching carby, and check lpg level in your tank... have that one before several times...
Feb 18, 2015 | Mitsubishi Cars & Trucks
Why is my LAND ROVER RANGE ROVER 4.0SE AUTO PETROL/ LPG GAS
Because a previous owner (or the dealer) wanted the lower cost of running on LPG using a dual fuel system so petrol (gasoline) could be used too. If the work was done professionally it provides the best of both but the downside is the reduction of usable space in the load space. You will find more about this in the "articles" page at http://www.graemecooper.com.au
Aug 12, 2014 | Land Rover Cars & Trucks
Lpg converted engine wont run using lpg without gasoline in tank
It is normal. All LPG converted engines start with gasoline. Then when they reach 2000 rpm move on LPG system.
If you want to start directly with LPG must call a professional to modify your installation.
Jan 30, 2014 | Cars & Trucks
Eu1000i runs and cuts off.....pump is good
If you haven't had it started for a while and have left gas in it, you probably have old/bad gasoline. Drain it and put new gas in. It may have clogged the fuel filter with rust and sediment from the old gas. Next time, put "Sta-bil" in it when you store it for the season, it will stabilize your gas.
Jun 21, 2012 | Honda Generator Cover Eu1000i Camo
I have an onan 5500 gas generator that wont start
What is the model? Chances are the carb needs cleaning or replaced.
Sep 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Conversion of yamaha gasoline generaor into natural gas...
i know YAMAHAwere doingsome work on converting outboard motors to run on LPG they may be able to get a bit of info from the STATE distributors might be worth a phone call
Jul 20, 2009 | Electrical Supplies
STARTS FINE (TECUMSEH H1OO ENGINE) BUT RUNS RICH. NO ADJUSTMENT AVAILABLE ON CARB. ANY SUGGESTIONS?
first off, is this an LPG, Nat Gas, or Gasoline powered unit? If you are sure that it is running too rich and you have no adjustment; the easiest way to reduce the volume of liquid going to the carb would be to put a regulating valve in the line somewhere. you could use a gate valve or even a ball valve if you had to.
Jun 04, 2009 | Coleman Powermate Powermate 5000W...
Petrol car not start on gas
are there any fuses to check why my car wont start on gas...?
Oct 21, 2008 | 1988 Daihatsu Charade
Powerland PD3G6500E Logo
Top Powerland Electrical Supplies Experts
Steve
Gene Haynes
Are you a Powerland Electrical Supply Expert? Answer questions, earn points and help others
