Question about Miscellaneous
How do I unload tape? - Miscellaneous
  • 937 Answers
Judging by what I can see, it looks like you may need to either swing the part on far left of the photo right out of the way or maybe remove it temporarily so that the tape can be removed towards the top of the photo. I guess the other side of the print gun looks the same as this side?
Posted on Jun 16, 2015
I cant operate my vcr there's a code on it L2 I can't change the channel or record nothing it's theL2
Haveing looked around the web I can only find results for the E2 code for this model.
E2 indicates that the loading motor is locked in the unload direction.
This means that when the tape was in the machine it tried to unload the tape and got stuck. There could be numorous causes for this that would require investigate. Till the fault is cleared the machine will be unoperational.
Nov 30, 2014 | Mitsubishi HS-U446 VCR
Tape is stuck in vcr
Someone will have to take it apart---usually it is a problem with the mechanism that loads/unloads the tape or the transport mechanism that moves the tape---the latter winds the tape back into the cassette and if fails it will hang up and or mangle the tape.
Oct 20, 2012 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Tape did not eject
if the tape can not eject by press the button, you can only unload it manually, but you'd better ask an expert to do it, such as me, haha.
Dec 01, 2010 | Dell PowerVault 110T LTO-2 Ultrium Tape...
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
I got the problem with my canon XL2 since last 3 months ago. The tape cannot unload sometimes. During recording and run out with tape, try to change with the new one but the cassette compartment cannot...
that is could be the cassette in switch or door swith inter mitent contact, or the mode switch for the mechanism position....
or a good clean up of the mechanism...
hope that will help you
regards allan
Sep 02, 2010 | Canon XL2 Mini DV Digital Camcorder
Auto off Unloading Lock I do not achieve that my chamber(camera) panasonic dvx100 expels the tape
When the movement of mechanical position does not completed
to move unloading direction within regular time.
must remove cas. cover and if tape is not slacked apply 4 volts on loading motor connector and the cas. will go out.This problem is not repairable by not authorized personnel.
Oct 22, 2009 | Panasonic AG-DVX100 Mini DV Digital...
Tape not ejecting from drive after 60 secs pressing eject button. I can hear it 'clicking' but no attempt to eject the tape is made. I would be very grateful for some advice regarding what I might do next.
can you detail the model No or compaq spares No for the drive - the clicking makes it sound to me like a DAT but unable to proceed without more info.
If it is a DAT (compaq used both Sony and HP mechs) try disconnecting the scsi cable from the scsi card, rebooting the drive and trying again.
If that doesnt work try a 00pt screwdriver in the manual eject point of the drive and unload manually (about 1000 turns!)
Failing that try www.tape-drive-repair.com as they are pretty good price wise for a repair / exchange
Aug 14, 2009 | Computers & Internet
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
HELLP ME
This sounds like it could be a tape sensor problem. Granted this is the worse case, but this is what this sounds like. In VCRs as the tape is pulled around the drum, a sensor determines if the tape is in the proper position. However if the tape is not the sensor triggers an unload sequence which unloads the tape and sometimes auto ejects the tape. I would forst try to use another tape just to see that it is not a tape problem (which 9 times out of 10 it will not be). After trying the new tape, see if you can get this looked at, by a qualified technician. I have done these repairs before and if it is an optical sensor what usually happens is magnetic dust gets on the sensor lens and causes problems, if the sensor is the switch type the switch tends to get out of alignment and needs to be set correctly or replaced. I hope this helps
Jan 10, 2007 | Jwin JD-TV1300 13 in. TV/DVD Combo
VCR tape stuck
Yes, it is a mechanical problem. While the tape is in fast forward the gears are engaged and locked to provide drive to the spindel on the right, however when you press the rewind button without hitting stop, the gears try to engage the spindel on the left without stoping and reversing (changing rotational positioning), this causes the motor to stop (this emulates a tape jam)the tope is left in and the unload mechanism never spools the tape back in because the motor has stopped. To free the tape, what I do is open up the unit and find the main motor check to see if the belt has slipped, if it has not try to manually spin the motor to engage the unload mechanism and eject the tape.
Dec 18, 2006 | Zenith VCS442 VHS VCR
Miscellaneous Logo
61 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
