Question about Miscellaneous
Which equation is it a,b,c, or d? - Miscellaneous
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 590 Answers
B. Equation of a circle is (x-a)^2 + (y-b)^2 = r^2, where (a,b) is the centre of the circle and r is the radius.
Posted on May 01, 2015
How do I graph an equation with TI 89?
Just open the Y= equation editor and enter your equation. Use X for T. Make sure the angle unit is in radians.
Nov 10, 2014 | Texas Instruments TI-89 Calculator
Edit Casio FX - 9860G SD have complex equations??
Thhe Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Apparently it will take coefficients that are real, and will give a Ma Error if any coefficient is complex.
Addendum.
The calculator CANNOT solve equations with complex coefficient. YOU can however convert the system of linear equations with ccomplex coefficients ( of the type you show) as a system of 4 linear equations in 4 unknowns; Split x into a real and an imaginary part, split y into a real and an imaginary part. Substitute Real(x)+iIm(x) for variable x in the equations; substitute Real(y)+iIm(y) for y in the two equations; do the algebra. In each of the original equations split the Real and imaginary parts. You should be able to derive 4 linear equations in unknowns Real(x), Im(x), Real(y), and Im(y).
Use the linear equation solver to obtain the solutions. Recompose x=Real(x)+iIm(x), and y=Real(y)+iIm(y)
Alternatively, after you create the system of 4 linear equations you can use the matrix utility to find Real(x), Im(x), Real(y) and Im(y) and recompose the x and y.
Mar 17, 2012 | Casio FX-9860G Graphic Calculator
Casio FX - 9860G SD have complex equations?? edit
The Casio FX-9860G SD can solve a polynomial equation of degree 2 or 3 with REAL coefficients. If the complex MODE is set to REAL it will find the real roots. If the complex mode is set to a+ib, it will find the real and complex roots.
Addendum.
Mar 17, 2012 | Casio Office Equipment & Supplies
Examples of homogeneous differential equation
Hi janeth sabay,
Have a good day!!
Here is your needed example for Homogenous differential equation:
The equation 49e8abf8a1c5be91fadbf33a5405bdc3.gif is said to be homogeneous if P and Q are homogeneous functions of x and y of the same degree.
We can test to see whether this first order equation is homogeneous by substituting 21fe29cd49ecbd3abe2ae6373e89eab6.gif . If the result is in the form f(v)i.e. all the x's are canceled then the test is satisfied and the equation is Homogeneous.
Example 1:19c981882c1f9b05fadf586b56a931bc.gif(2)
There are no terms in x on the right hand side and the equation is Homogereous.Example 2:72f80f87eb510a9e0fd81c423b3faa55.gif(4)
So the original equation is not homogeneous.Methods Of Solution.
A solution can be found by putting y = vx on both sides of the equation:-
Example 3:
Putting y - vx
Since y is a function of x so is v
Separating the variables
Integrating
Substituting (12) in equation (10)
405d0e82aab0e4cb688a90b92a0dab77.gifI can suugest you also to visit this site for more examples http://www.codecogs.com/reference/maths/differential_equations/homogeneous_differential_equations.php
Sep 12, 2011 | Toys
Hello How to solve complex equations using casio fx 9860G AU For example (2+i)A+B=6 2A+(1+i)B=1 How to solve A and B using this calculator
The simultaneous equation solver requires the coefficients to be real. Similarly matrices must have real coefficients.
Your only alternative is to express each of A and B as a real part and imaginary part.
A= x1+iy1
B=x2+iy2.
Substitute x1+iy1 for A in the two equations. Substitute x2+iy2 for B in the two equations. Do the algebra. Gather real parts and gather imaginary parts. Split each original equation into two equations: One equation comes from setting Real Part of left side = real part of right side (1); the other equations comes from setting the imaginary part of left side= imaginary part of right side (here 0).
Do the same procedure for the 2nd original equation.
At the end of the process you will have 4 coupled linear equations in the 4 unknowns (x1,y1,x2,y2).
Then you might want to use the calculator to solve the derived system. Once you have x1,y1,x2,y2 you reconstruct A=x1+iy1, etc.
Aug 29, 2011 | Casio FX-9860G Graphic Calculator
How to do equations the papers that come with it doesn't explain it very well. Is there someplace where I can get a better explaination?
You can solve equations two ways: The EQN computational mode or the SOLVE application.
IN the EQN mode you can solve linear equations in one, two and three unknowns; the quadratic equation; and the cubic equation.
Enter the EQN mode by following the instructions on the following screen capture. Press 5:EQN
You have three types of equations.
Once you select the type of equations, a template is displayed where you enter the relevant coefficients.
Under each label (a, b, etc. ) enter a coefficient and press ENTER to move to the next. With a cubic equation, or a linear equation in 3 unknowns, you have to use the Right arrow to display the cells where you enter the value of d.
After you input all necessary coefficients press the = sign to get the solution.
To use the SOLVE feature, see the screen capture that follows. It comes from the Casio manual.
Good luck
Jun 24, 2011 | Casio FX-115ES Scientific Calculator
What are the equations and its kinds?
Definition
A mathematical statement used to evaluate a value. An equation can use any combination of mathematical operations, including addition, subtraction, division, or multiplication. An equation can be already established due to the properties of numbers (2 + 2 = 4), or can be filled solely with variables which can be replaced with numerical values to get a resulting value. For example, the equation to calculate return on sales is: Net income ÷ Sales revenue = Return on Sales. When the values for net income and sales revenue are plugged into the equation, you are able to calculate the value of return on sales.
There are many types of mathematical equations.
1. Linear Equations y= mx + b (standard form of linear equation)
2. Quadratic Equations y= ax^2+bx+c
3. Exponential Equations y= ab^x
4. Cubic Equations y=ax^3+ bx^2+cx+d
5. Quartic Equations y= ax^4+ bx^3+ cx^2+ dx+ e
6. Equation of a circle (x-h)^2+(y-k)^2= r^2
7. Constant equation y= 9 (basically y has to equal a number for it to be a constant equation).
8. Proportional equations y=kx; y= k/x, etc.
Jun 14, 2011 | Computers & Internet
How to name custimized equations
Use the colon
EQUATIONNAME: EQUATION
Oct 28, 2008 | HP 17bII+ Calculator
Equator EZ 2500C - Need a pump
You can contact Appliance Desk who carry parts for all Equator models.
You can get their contact information from their website www.appliancedesk.com and also place the order online.
Mar 27, 2008 | Equator EZ 2500C Front Load All-in-One...
Microsoft equation
Microsoft Equation is an optional component and is not automatically installed. To install Microsoft Equation, you have to run the Office Installer, and select Custom Installation. The installation wizard will present you with the optional components to install. Find Microsoft Equation, and make sure the Run this in my computer option is selected. Then continue with the installation. Office will configure itself to include the Microsoft Equation program.
Sep 21, 2007 | Microsoft Office Standard for PC
Miscellaneous Logo
64 people viewed this question
Top Miscellaneous Experts
russ davis
Rick Oudette
Rick Oudette
Level 1 Expert
Dale
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
