An equation of the circle whose center is at(2,-3) and whose radius measures4 is it A, B, C or D?
  • 601 Answers
A. The equation of a circle is (x-a)^2 + (y-b)^2 = r^2, with (a,b) being the centre of the circle and r being the radius.
Good luck,
Paul
Posted on May 01, 2015
2 Suggested Answers
remaker
  • 449 Answers
SOURCE: what is the length of
You can use this tool: http://www.mathopenref.com/trianglecircumcircle.html
7.12 is the radius of the circumcircle, also called the triangle's circumradius.
Posted on Sep 25, 2011
Which equation is it a,b,c, or d?
B. Equation of a circle is (x-a)^2 + (y-b)^2 = r^2, where (a,b) is the centre of the circle and r is the radius.
May 01, 2015 | Miscellaneous
Write the equation in standard form for the circle with radius 1 centered at the origin.
The formula for a circle in standard form in (x-h)^2 + (y-k)^2 = r^2, where r is the radius, the point (h,k) is the centre of the circle, and ^2 means squared.
Substituting in 0 for h and 0 for k, and 1 for r, you will get your formula.
Good luck.
Paul
Apr 15, 2015 | Office Equipment & Supplies
Circle equation
If you know the center, measure the distance between the center and one point on the circumference. Measure with the opening of a compass and report on a ruler, or use a ruler.
Take the measure of the radius and multiply by 2. Any other indirect way of getting the radius does not constitute a measure but a calculation.
The diameter of a circle enters in two formulas.
Length of Circumference: C=Pi*D (D diameter) ====>D=C/Pi
Area of the disk A=Pi *D^2/4 =====>D=SQRT(4*A/Pi), SQRT is the square root operation.
Dec 31, 2013 | Office Equipment & Supplies
Find the radius of the equation x^2+y^2-2x-2y=14
Try casting the equation of the circle into the form (x-h)^2+(y-k)^2=R^2. Here (h,k) would be the center and R the radius.
To do that complete the two squares.
x^2-2x=x^2-2x+1-1=(x^2-2x+1)-1=(x-1)^2 -1.
Do the same for the y terms.
y^2-2y=(y-1)^2 -1.
Substitute these two expressions in your original equation.
(x-1)^2+(y-1)^2 -1-1=14 or (x-1)^2+(y-1)^2=14+2=16
The radius is square root of 16 or 4, and the center is C(1,1).
Sep 20, 2011 | SoftMath Algebrator - Algebra Homework...
To graph a circle with radius 4
Press [2nd][PGRM] to open the (DRAW) utility. Scroll down to reach the line 9: Circle( and press ENTER. Complete the command by supplying the coordinates of the circle center and the radius.
Circle(0,0,4) draws a circle with center at the origin (0,0) and radius 4.
By the way the equation of a circle is not a function. You have to cut it into the upper brach and the lower part to graph it.
y=+SQRT(16-x^2) and y=-SQRT(16-x^2)
Sep 01, 2011 | Texas Instruments TI-84 Plus Silver...
Find the equation of the locus of a variable point P if P is 2 units distant from (-1,-2)
The equation of a circle with radius 2 and centered on (-1, -2) is
(x+1)^2 + (y+2)^2 -4 = 0
Oct 17, 2010 | Cameras
There is an equilateral triangle. in it there are three coins of equal radius is placed. find the radius of the coin.
how big is the triangle? if the coins are a mile in diameter doesnt mean you cant have an equilateral triangle with legs of 32 miles long.
or are you asking for the equation?
i will send you on the path to the equation.
if you draw a circle on a piece of paper then draw a triangle around it where is the center? if the triangle were a perfect equilateral then the circle would be a perfect circle touching the sides of the triangle.
its important to know where the center is because the center of the circle to the edge of the circle is the radius.
so the center of a triangle is the center of the circle. therfeore the radius of the circle will equal hieght/2...
thinking that way you can say that if there were three coins then the center of the triangle cant be occupied by a coin but is very close to an edge. where is the center of the coin?
Jun 10, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
WHEN GRAPHING A CIRCLE ON THE TI83, THERE ARE POINTS MISSING.
Use the DRAW program.
Press [2nd][PRGM] (DRAW)
Select [9:Circle (]
Command echoes on main screen
Complete the command with coordinates of the center and the radiius
Close parenthesis and press [ENTER]
The circle is displayed.
Ex: Circle(0,3,2) draw a circle with cntere at (0,3) and radius equal to 2.
Alternatively: If the conics application is on the calculator run it.
Press [APPS]
Select [Conics]
Select [1:CIRCLE]
Choose the canonical form (X-H)^2 + (Y-K)^2=R^2 where H, and K are the coordinates of the center and R is the radius.
You will be prompted to enter the values for H,K, and R
You can also use the general equation for a circle aX^2 +aY^2+BX+CY +D=0
Enter the values of a, B, C and D.Change the values to get what you want.
Apr 01, 2010 | Texas Instruments TI-83 Plus Calculator
Analytic geometry
assuming the question is what is the circle equation?
and if (-2,2) is the center of the circle
the equation should look like this: (x+2)^2+(Y-2)^2=R^2
And now only R is needed.
given 2x-5y+4=0 equation of line perpendicular
we can rearange the equation to be y=(2x+4)/5
from that we can see that the slope of the line is 2/5
And from the fact of perpendicular line we can say that the slope
of the radius line is -2/5.
The motivation now is to calculate the distance between the center of the circle to the cross point of the radius with the line perpendicular
For that we would calculate the radius line equation and compare it to the equation of line perpendicular
As mentioned earlier the slope of the radious line is -2/5.
So the equation is y=-2/5x+b and b can be calculated by using the center of the circle coordinates
2= - (2/5)*(-2)+b ------> b=2-4/5=1.2
radius equation is y=-(2/5)x+1.2
Now the cross point is calculated by comparing the equations:
-(2/5)x+1.2=(2x+4)/5 --> -2x+6=2x+4 --> 4x=2 --> x=1/2 --> y=1
So the cross point is (1/2,1).
The distance between the points is calculated by the following
Formula:
R=SQR(((1/2)-(-2))^2+(2-1)^2)=SQR(2.5^2+1^2)=SQR(6.25+1)=
SQR(7.25)
Therefore the circle eq is (x+2)^2+(Y-2)^2=7.25
Oct 26, 2008 | Casio FX-115ES Scientific Calculator
73 people viewed this question
jasbo
jasbo
