Question about Lands Phones
How can i take off ,answer with message? - Lands Phones
How do I retrieve recorded messages from an outside phone?
You can access the answering system remotely by dialing your home telephone number from any touch-tone telephone. To remotely access the answering system
Dial your telephone number from any touch-tone telephone. When the answering system answers, enter the two-digit remote access code (19, unless you have changed it). The answering system automatically announces the number of messages (new or old) if there are any. If there are new messages, the answering system automatically begins to play new messages only. -OR If there are no new messages, the answering system automatically begins to play all old messages. You can also enter the remote commands: Play all messages
1 Press to listen to all messages. If there are new messages, the system plays back only the new messages (oldest first). If there are no new messages, the system plays back all old messages (oldest first). Play new messages
2 Press to listen to new messages only. Delete a message 3 Press during message playback to delete the current message. Delete all old messages
3 Press to delete all old messages. Replay current message or previous message
4 To repeat the message currently playing, press 4 after the answering system plays the day and time the current message was received. To listen to the previous message, press 4 while the answering system is playing the day and time the current message was received. Stop
5 Press to stop playback and recording. Play help menu * 5 Press to listen to a list of remote commands. Skip to next message
6 Press during playback to skip the current message and advance to the next message. Record a announcement
7 Press to record a new announcement. Begin speaking after the long beep. Turn system on or off 0 Press to turn the answering system on or off. Exit
8 or hang up Press to end remote access (the call is terminated). 1. 2. 3. 4.5
0 Answering system Remote access Hang up to end the call and save all messages.
NOTES: If you do not enter a valid remote access code, the system answers the call automatically. If the date and time is not set when a message is recorded, the system announces, "Time and date not set" before the answering system announces the number of messages. If there are no messages in the answering system, the system announces, "You have no message." If there are no new messages in the answering system, when you press 2 to play back new messages, the system announces, "You have no new message." If you pause for more than four seconds during remote access, you hear a help menu listing all features and commands. If there is no command for another 20 seconds, the call ends automatically. If the memory is full, the answering system answers after 10 rings and announces, "Memory is full. Enter the remote access code." Enter your remote access code to access the messages and announcements. When the answering system is turned off, the telephone answers after 10 rings and announces, "Please enter your remote access code."
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Vtech model 6053 answering machine will not record message
Perhaps your answering machine needs to be set set to accept messages. Maybe your message machine memory is full of messages?
Aug 03, 2012 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i erase messages
To erase a message while it is playing, press the ON/OFF ERASE button. The
answering system announces, "Message Erased" to confirm the message has been
erased.
To Erase All Messages: When the answering system isn't playing or recording messages, press and hold
the ERASE button until you hear the "Messages Erased" announcement. Release the
button after the announcement. This feature allows you to erase all old messages
but not new messages. If you do not have any messages, the answering system
announces, "Zero Messages."
User Manual: http://www.home-electronics.net/USER-GUIDES/29875_DOM_EN_AN_IB.pdf
May 06, 2011 | GE 29875GE Digital Answering Machine
When people leave me a message - the answering machine does not show that I have a message. The person calling hears the greeting - leaves a message, but I do not receive the message.
It may be similar to the problem I had on wireless home phone with answering machine not taking messages when had the answering machine set to 12 rings before answering. Found the sim card (my wireless system) auto response would answer first. Fixed it by reducing time to 6 rings and answering machine now comes on first.
Oct 12, 2010 | Uniden Cordless Phone
I have Comcast on my phone & have had the phone answering taken off from them, however, I cannot put a message on my GE phone answering system. The "phone lady" answers saying we are unavailable at...
The phone lady thats answering the line,it that message through comcast or the GE answering machine? Also, whats the model number of the GE answering system?
Jun 09, 2010 | GE Lands Phones
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Retrieving message
See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
from the following chart:
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Mar 18, 2009 | Uniden DXA15588-2 Twin Cordless Phone
Picking up messages remotely
Try this...
Remote Operation
Command Function
Dec 12, 2008 | GE 25942GE2 Cordless Phone System
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
Nov 09, 2008 | Radio Shack 3825 Answering Machine
Phone answering machine
Moving a Message to Another Mailbox
You can move a message from one mailbox to another. The message is saved a a new message in the mailbox to which it's been added and is deleted from the original mailbox.
1 While the message you want to move is playing press "setup". The system beeps and stops playback, the Message Window displays CP (for copy) and the Mailbox lights flash.
2 Press the MBox button where you want to move the message. The system resumes playing messages in the original mailbox.
Aug 10, 2008 | AT&T 1726 Digital Answering Machine
Lands Phones Logo
125 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
