Question about Electrolux Epic 6500 Vacuum
I have an Electerlux Epic 650rx and the beater bar is not turning on. Is there a fuse and how do I replace it?
  • Lori Bowen
    Lori Bowen Jun 04, 2015
    How can I tell if the reset button needs replaced?
  • 113 Answers
The problem could be a litany of things. If there is a reset button try that first.Then try pluggling the power head directly into the hose.If that doesn't help get back to me sorry I can't be more helpful but it's hard to diagnose these issues without seeing the machine.
Posted on May 01, 2015
  • Chris Nomland
    Chris Nomland Jun 04, 2015
    Hi Lori,it's very rare for a reset button to burn out but it does happen. Take the top off to expose the motor,brush and reset etc. Ru the Power nozzle and wait for it to cut out.When it does push the button again to restart and see how long it goes before shutting down.When it shut down check to see if the motor is hot. Lot's of times it is the motor itself that burns out. If you can't get a clear diagnosis get back to me and I will explain how to by-pass the reset. It'is difficult for e to figure this out without looking at it....Chris
How do I find the belt on the electrolux epic 6500. My husband picked up a scarf end, and now the brush won't turn to clean the rug. A rectangular light came on, I do not know what that means.
Turn off power. Remove the screws in the bottom plate of the vacuum head. The belt is around the beater bar inside the power head. Pull the beater bar out of its bracket to access the belt.
Jun 22, 2015 | Vacuums
How do I replace the fuse in the canister body?
there should be a reset butto on the right side of the power head.If so try pushing that first,then ge back to me.. Chris
Jun 04, 2015 | Electrolux Epic 6500 Vacuum
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Noisy beater bar
end bearings need replacing
Aug 10, 2014 | Electrolux Epic 6500 Vacuum
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
WHEN I TURN MY VACUME ON IT SOUNDS FINE, WHEN UPRIGHT. WHEN I GO TO MOVE IT TO HOOVER IT MAKES A SCREAMING NOISE. CAN U TELL ME WHAT IS WRONG PLEASE AND HOW TO FIX. THANK YOU
When the vaccum is upright, the beater bar is not engaged. When you tilt the handle back, the clutch engages and the beater bar begins to turn.
There are two likely possibilities for the "screaming noise". First, and most likely, is that the beater bar cannot turn because of a build up of debris or the beater bar is broken. In eaither case, the clutch belt is spinning on the non-moving beater bar causing the noise. Remove the beater bar, inspect for hair, carpet fibers or other items wrapped around the bar. Also inspect for cracks in the plasitc at the ends of the bar. Clean or replace the bar as needed.
The second possible cause is the clutch assembly. If you were unable to fix the problem with the first solution, it is time to take the vacuum in for service as replacing the clutch is somewhat difficult.
Here is a YouTube video link that will walk you through the process of removing the beater bar as well as the clutch if you decide to go it on your own: http://www.youtube.com/watch?v=7_CtaFcc5HU
Hope this helps.
Sep 23, 2009 | Dyson Vacuums
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Vacuums Logo
149 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
