Question about LG Washing Machines
Wf-t7016pp.....finishes rinse cycle but does not spin
Adjusted belt tension and checked wiring. found clutch system appears to be working but the drum pulley appears to be locked.
    Genius:
  • LG Master
  • 1,585 Answers
The prob is pump blockage
Posted on May 01, 2015
Spin not working on final cycle
no rinse at all or just at second final cycle? if so its either bad clutch, tranny, motor coupler, belt broken, or even door switch out? depending on either a belt or direct drive motor
Dec 19, 2014 | Washing Machines
I have a Maytag Neptune topload washing machine, Model #FAV6800AWW. When washing machine is finished the clothes are still wet but no water in the drum. Also we have noticed that during spin cycle th
Before calling for service:
If clothing is still wet it means no spin. The most common problem with this model is a loose connection from the lid switch to the control board. Two white wires going from the lid switch to the control board should be cleaned. Do not touch the control board - especially in dry climates. Static electricity can ruin a board.
Nov 11, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Lg wf -t7016pp not spinning,why?
You seem to have a broken component in the machine- I would call the LG contact number and inquire there- depending on how old the model, serial number, date of purchase, proof of purchase, you may get replacement parts and a washing machine isnt too complicated to navigate around. Im sure you could fix it :) But wish you the best of luck- If not- Second hand shops that sell these devices are usually very knowledgeable and for a small fee- you could have it working in no time.
Aug 11, 2014 | LG Washing Machines
Hotpoint 1050 model 9605 not spinning
direct drive has clutch and tranny. belt is belt driven. there is a tensioner belt switch that may have clicked off somehow? located at bottom of tensioner on motor. may also want to check the lid door switch, ( looks can be decieving as u say it looks to be working) check all with a multimeter for continiuty
Aug 08, 2014 | Hotpoint Washing Machines
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
Clutch chatter - Replacing the drive belt helped a little. Is there a way to adjust the clutch?
there is no clutch as far as I know on ride on mowers, there is just a tensioner pulley that works off the brake/clutch, to adjust it you have to depress the brake/clutch to take the tension off the belt then adjust the belt tensioner to apply more pressure on the belt. Also check the tensioner pulley as I have found that they split in two and the belt becomes loose as a result.
Hope this helps
Oct 20, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
Won't spin to drain clothes still wet when finished
You may have a control board issue. I would recommend calling in someone to look at it.
Price out replacement vs repair it maybe time for a new machine.
T
Jul 03, 2008 | Frigidaire GSTR1670A Front Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
