Question about Dell 3110cn Laser Printer
The printer is saying check Y cart 093 919. What is that?
  • Dell Master
  • 15,756 Answers
The yellow cartridge is empty, loose or failed.
Posted on May 01, 2015
Alarm light on, says wrong cartridge, but they are the same ones that were in there. what do I do?
take out the cart and clean the contact.. the part where the cart touches the printer.. check if it's contaminated with ink.. just wipe it with tissue and make sure the cart holder in the printer is clean as well.. pls switch OFF the printer while cleaning.
May 24, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Dell Photo 926 printer keeps saying that it cant align and wont print after installing new cartridges. Says tape is still on there but it isnt.
1. cancel the alignment .
2. try one cart at a time and only make a copy of a test document ...(press "select" if u get cart missing error ) ...only of the carts is causing the error
3. possible u have defect cart ..or the internal sensor could have gone bad (rare scenario )
4. get a replacement carts...
Oct 25, 2009 | Dell 962 Photo All-In-One InkJet Printer
Put in new cart. in 2110 psc it says to remove and check cart.won't accept and operate
OPEN THE TOP UNIT.remove the cartridges .you can see metal contacts in the printer carrage unit.clean the contact with soft tissue cloth.
Oct 24, 2009 | HP PSC 2110 Color Printer
The printer says no cart. installed. Then I put all new ink cart in and it still says no cart for all 3 colors. Help
Might need to remove all carts, power down and unplug for a few seconds, power up and install inks as they are asked for on the screen. Machine just gets confused...
Jul 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Display says toner out even with new cart. Setting new cart message in resets menu to yes does not work, selection reverts back to no. Customer is using reman carts.
A number of companies use a fuse that blows when the cartridge is low. If the fuse is not replaced, it will still say "toner out". The reman should have replaced it.
Jul 27, 2009 | HP LaserJet 4100 Printer
Printer won't recognise new cartridges
HP Printers are inteligent... use genuine light black cartridges which are inexpensive and do not bug up your printer too.
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
PRINTER SAYS NO CARTRIDGE CARTRIDGES HAVE BEEN CHANGED
Unplug machine from power outlet. take all carts out. leave cover open. wait 5 min. plug machine to power and close cover. machine will demand carts. reinsert carts and answer question given on display.
If you still have trouble this might be due to the generic carts which have not the right construction. use original carts.
Dec 17, 2007 | Brother MFC 420CN All-In-One InkJet...
My MFC-210C always says replace ink.
Try this: Unplug machine from power. Wait 5 min.  Open scanner cover and take the carts out of the holder. Close cover. Plug machine to power. Machine will cycle and demands the carts. Use all NEW carts: Insert carts as demanded and answer question shown on display.
Always print until machine STOPPS printing because of EMPTY cart. Change cart then and machine will print the rest of job!
Plz, never change carts when it says NEAR EMPTY: This will cause a lot of trouble ;-)
Nov 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Edweard
Take all carts out. Close cover. Unplug machine from power. Wait a minute. Plug in machine to power. Machine demands carts. Insert new (!) cart as demanded from machine. In case when asked push 1 for YES: cart changed.
BTW:
Always print until machine stopps printing. Display says NO INK XY. After replacing the cart machine will print the rest data out of its memory.
NEVER change cart when machine says low ink (This is only a hint to buy a new cart!). At this point the cart has about one third of ink left!
Nov 01, 2007 | Brother MFC 420CN All-In-One InkJet...
Dell 3110cn Laser Printer Logo
115 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
