How do i start the magic square 5x5 1through 25 with 25 in the right corner
  • 3,957 Answers
Here is a good discussion on solving magic squares, with an example of your problem. http://www.jonathandimond.com/downloadables/Magic%20Squares.pdf
Posted on May 01, 2015
How to reset password,bios
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits
in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and
pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in
upper left corner( laptop battery slot is on right, DVD
drive is facing away from you)
5)Using a magnifying glass (unless you have perfect
vision)in the upper left corner you will see JOPEN1 with
a white silkscreen square next to it . Inside the square
you will see what looks like the letter T over a U.
Using a metal paper clip short the U to the Silver 1/4"
post connecting the motherboard to the laptop case(this
is you ground, it is located above what looks like a
silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery
and test start laptop. you should see a selection of F1
or F2 for setup. Using the F2 gets you into the Bios
menu where you reset the time and date. Then Tab over to
the SECURITY setting tab and change your passwords. Now
hit F10 key ,yes to save and your done!
check the video as well
https://www.youtube.com/watch?v=Eo1gg1EZV-o
Apr 03, 2015 | Toshiba Satellite A135-S2276 Notebook
How do I send photos from album to messages
in an album, viewing photo's, tap once on the photo, so you see the white bands on top and bottom. in the left corner down on the screen you see a square with an arrow tap that. you see a blue tag in the right bottom corner of the picture you now can select more pics, till you are ready and on the top right tap next. choose mail and compete the mail and press send.
Be aware most providers don't accept multiple pictures attached (gmail does, but only till about 25 Mega byte).
Success
Jul 18, 2014 | Apple iPhone 5
I need to reset the bios password on my daughters laptop
ReSetting Bios Password on Toshiba Satellite A135-S2386
2)Take off Memory Cover(underneath - square cover, Sits in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in upper left corner( laptop battery slot is on right, DVD drive is facing away from you)
5)Using a magnifying glass (unless you have perfect vision)in the upper left corner you will see JOPEN1 with a white silkscreen square next to it . Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4" post connecting the motherboard to the laptop case(this is your ground, it is located above what looks like a silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Now hit F10 key ,yes to save and your done!
Note: if your having trouble your most likely grounding the ground(that blob of solder about 1/8"dia on both ends of the "silkscreen chip outline"
Sep 23, 2010 | Toshiba Satellite A135-S2386 Notebook...
SEVEN SQUARES ON A PIN BOARD I CANT GET IT
Hi there,here is you answer,enjoy
There are 6 lines of pins
On each line they are in different positions
So for this occasion we are gonna number these from 1-28,from left to right then from top to bottom
We will give each square a colour and a number
1*Large blue square join the 4 corners at pins 8 to 16 to 23 to 28
2*Large yellow square join at pins 4 to 12 to 21 to 27
3*Small red square join at pins 17 to 22 to 24 to 26
4*Small brown square join at pins 14 to 18 to 20 to 25
5*Small light blue square join at pins 5 to 9 to 11 to 15
6*Small white square join at pins 1 to 2 to 6 to 7
7*Medium white square join at pins 3 to 10 to 13 to 18
Hope this helps its the easiest way i think i can describe it
JonnieC
Jan 06, 2010 | Nintendo Professor Layton & the Curious...
How to use crop tool,magic?
yuo want to know how to use the crop tool and the magic wand?
crop tool works just like everything else it works like it does in word powerpoint ect
the magic wand
this selects the areas which are the same colour which are touching each other
imagine in a picture filled with back the corners are white but the white corners are not touching each other when you click on one of the white corners with the magic wand then that whole white secon of that corner will be selected
and to make that into a layer you can either copy that selection or cut it from the original
by right clicking and selecting either layer via cut or layer via copy
http://phototests.com/Photoshop/help.html
go here it is a really good page on photoshop help
Jan 02, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
I need help with puzzle 100
There are 28 PINS -- Count each PIN starting from left to right on each line. (1 -- 28)
Square ( 1) Join together Pin No's ( 1 -- 2 -- 6 -- 7 )
Square ( 2) Join together Pin No's ( 4 -- 12 -- 21 -- 27 )
Square ( 3) Join " " " ( 5 -- 9 -- 11 -- 15 )
Square ( 4) " " " " ( 3 -- 10 -- 13 -- 19 )
Square ( 5) " " " " ( 8 -- 16 -- 23 -- 28 )
Square ( 6) " " " " (14 -- 18-- 20 -- 25 )
Square ( 7) " " " " (17 -- 22 - 24 -- 26 )
GOOD LUCK.........
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
How to solve no 100: seven squares
There are 28 PINS. Count each PIN starting from left to right on each line. (1 to 28 )
Square 1-- Join together PIN No's ( 1 -- 2 -- 6 -- 7 )
Square 2 -- Join " " " " ( 4 -- 12 -- 21 -- 27 )
Square 3 -- Join " " " " ( 5 -- 9 -- 11 -- 15 )
Square 4 -- Join " " " " (3 -- 10 -- 13 -- 19 )
Square 5 -- Join " " " " (8 -- 16 -- 23 -- 28 )
Square 6 -- Join " " " " (14 --18 - 20 -- 25 )
Square 7 -- Join " " " " (17 -- 22 - 24 - 26 )
Hope you can complete this Puzzle now ----------- GOOD LUCK
Apr 01, 2009 | Nintendo Professor Layton & the Curious...
Write a program to calculate Magic square Number A[4][4]
From Joe-Bob's handy-dandy reference:
(wikiedia...)
Normal magic squares exist for all orders n ≥ 1 except n = 2, although the case n = 1 is trivial—it consists of a single cell containing the number 1
The constant sum in every row, column and diagonal is called the magic constant or magic sum, M. The magic constant of a normal magic square depends only on n and has the value
13652227c2537f1018ce4d011d792db1.png For normal magic squares of order n = 3, 4, 5, …, the magic constants are:
15, 34, 65, 111, 175, 260, …
Feb 23, 2009 | Computers & Internet
Re: professor laytons seven squares
Not my brilliance I'm afraid, but found the answer on another website, have copied in below - it does work!
It is very complicated to explain but i'll try as best as I can. 1- First make a small square in the top left corner.(This is the only one that isn't at 45 degrees)
2- Next go to the far bottom left corner and make a small 45 degree (lop sided) square leaving only one peg in the middle.
3- Copy the same thing as you did for the 2nd square but this time in the far top right corner.
4- Use the peg that is in the centre of the square in the bottom left corner(2) and draw a line to the peg on the far right at the very bottom. Then draw a line to the middle peg on the far right. Then draw a line to the peg that is on the 2nd row from the top and 3 columns in from the left. Then complete the square connecting up the other side.
5- Start from the peg that is on the very far right that is free and connect it to the peg that is free at the very bottom. Then connect that to the peg that is free on the far left. Then connect it to the peg at the very top (out of the 2 that are free) on the right. Then complete the square.
6- At the very top start at the free peg and connect it to the free peg on the right that is in the centre of the small 45 degree square. Then connect this to the free peg in the centre of 4 other free pegs. Then connect that to the free peg that is furthest to the left and then complete that square.
7- As there are only 4 pegs left this should be easy to see a small 45 degree square. Hope this helps and didn't confuse you too much.
Nov 24, 2008 | Nintendo Professor Layton & the Curious...
Green 5 in lower right hand corner
dont worry about the magic focus check the convergance that all guns align.
Feb 20, 2008 | Hitachi 61SDX01B 61" Rear Projection...
54 people viewed this question
jasbo
jasbo
