Question about Uniden D1680 Cordless Phone
Why can't I change code? - Uniden D1680 Cordless Phone
    Habit-Forming:
    New Friend:
  • Uniden Expert
  • 92 Answers
With the phone in standby, open the menu; select Ans. Setup, then select Security Code. Use the number keypad to enter a two-digit security code (01 to 99). Press Menu/select when you're finished.
Posted on Jun 19, 2015
How do i change my pin code
Do you want to change security pin code in your phone ? If so, first reset your phone using Master reset code when you forgot security code . You can get it from the provider Unlock-Free.com as free of cost . After that, change your security pin code .
Nov 10, 2014 | Locks & Locksmithing
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
What should i have to do for change security code?
Your Nokia phone was designed with a default security code of 12345.
To change it,
1. Go to 'settings' on your phone.
2. Then 'security'.
3. Then 'access codes'.
4. Then 'change security code'.
5. When you select to change security code,
it would prompt you to enter the security code (initial one, ie. 12345).
6.When you have entered the intial one, it would prompt for the new code.
7. Enter any 5- digtit new code of yours.
8. It would prompt for a confirmation.
9. Re enter the new code.
And your security code is changed. But remember to use number you can easily remember.
Hope that was helpful?
Regards.
May 20, 2011 | Nokia N73 Music Edition Smartphone
SAMSUNG S5233 WHY THEMES IS NOT DOWNLAOD ?
Tired of memorizing new PIN codes? We show you how to change your SIM card's various PIN and PUK codes in less than 5 seconds.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
<a href="http://www.5starandroid.com">Android Mobile</a>
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
I want to change my security code. Right now its the same default code 12345. But dont know how to change it as i desire?
To change your security code from the default, follow these steps carefully;
  1. Press Menu
  2. From Menu, go to Settings,
  3. From Settings, scroll to Security settings
  4. From Security Settings, go to Access Codes,
  5. Press Access codes and you would see Change Change Security Code.
  6. Press Change Securty code and you would be asked to enter your old security code (which is 12345, the one your are presently using) and thereafter, you would be required to enter the new security code.
I wish you the best and don't forget to rate this.
Dec 29, 2009 | Nokia 6233 Cellular Phone
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
I have an lg vu and i wanted to see what happens after the pin is gone 5 times now my screen just sayz puk blocked please need help!!!!!
If all else fails, you can use cellunlockstore.com for $1.99. Try the instructions below.
To change your SIM card's various PIN and PUK codes:
Change SIM Card PIN
Jul 19, 2009 | Cell Phones
How can i type the master code(reset code)
Hello, If you didn't change your code before it's 12345. If you changed it you should check this page _____(http://www.gsm-forum.eu/unlocking-codes-log-ile-requests/15278-all-nokia-bb5-security-code.html_____ and follow the instractions. Most probably you will get our code... After you find it,you can change it from your phone security settings... [But if you are talking about to change or find your SIM unlock code its not possible to fix it here :) ] Good luck....
Jan 19, 2009 | Nokia 6300 Cellular Phone
Uniden D1680 Cordless Phone Logo
71 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
