Question about Garden
How can I find a drive pulley diagram for this older mower, serial # unreadable?
  • 3,957 Answers
Google search the manufacturer make, model and words drive pulley diagram. If it is available, you will find it in the search results along with images. Serial numbers have no bearing on searching for these types of answers.
Posted on May 01, 2015
    Top Expert:
  • Garden Master
  • 50,269 Answers
Google make perhaps you can get luckey
I need to know how to install drive belt on cub cadet that has hydro drive with diagram
That will depend on the model of your mower. Generally you have to remove the deck and deck belts. The drive belt usually goes from the engine pulley to the transaxle pulley. There may be a tensioner pulley as well that keeps the belt tight.
Jul 11, 2016 | Cub Cadet Garden
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
Free belt diagrams
If you told me your model and serial # and make I would be able to help you
Aug 30, 2014 | Garden
Will not drive
You haven't indicated what mower you have, but in general terms , check to make sure the drive belt is not broken. There is a tension wheel on most mowers which puts tension on the drive belt when the clutch is out.There is usually an idler pulley that puts tension on the drive belt.Sometimes a tensioning spring breaks or comes off a pulley. So confirm that the drive belt is intact and that there is tension on the belt. If this did not help, please forward info on the mower; brand, model #, serial #, and I will try to help you further.
Apr 19, 2014 | Garden
Diagram for drive belt pulleys for cub cadet 1045
Round the two outer pulleys on the deck. Round the the outer pulley in middle deck, round idle pulley inside, next pulley in center of deck to drive pulley
May 03, 2012 | Garden
I posted the below problem last night with the request for additional information reply sent 2 hours ago. I need to use this mower today. I need to have an answer. THanks Problem with the...
Thought I posted a solution earlier on this, but it was my first post and I don't see it here so I'll try again.
Google search on your model shows the drive belt diagram on page 27 of the manual.
link below:
http://www.mytractorforum.com/images/reference/dgs6500.pdf
Looks like mine.
basically need to remove front pulley by loosening center bottom bolt while holding the center nut on top of motor.
Slip belt over the rear pulley first and then straight toward the front, slip belt on front pulley and then slide pulley back onto shaft.
Then wind through the rest of the pulleys etc..as seen in the diagram.
Jun 08, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a ariens yard tractor YT 150 H model number 936012 serial number 004697 . I have replaced the pto switch and the relay and every time I engage the blades the mower cuts off. Could you please tell...
I have the same model and had the same problem. Ended up being a bad bearing in one of the deck pulleys. You can find it by disconnecting the drive belt for the blades and turning the pulley by hand. One of them is going to be a lot tighter than the other. You should probably replace both while you have it torn apart...
Oct 22, 2010 | Garden
Lawn Mower belt came off of pulleys
www.stollerlawnandgarden.com/
Go to this website, click on parts lookup in left hand column. Choose MTD then enter 13AN model number. Click on deck and it will show you how to route the belt. Hope this helps.
Jun 23, 2009 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
