Question about Grundig Audio Players & Recorders
How to setup remote comptrollers - Grundig Audio Players & Recorders
If I Am No Longer Running A Business, Can I Keep My Sales Tax Permit?
Your permit applies only as lengthy when you are positively involved in business like a seller. If you're no more performing business, you need to return your permit towards the Comptroller for cancellation. Likewise, the Comptroller may cancel your permit whether it finds that you're no more involved in business like a seller.
Jul 07, 2015 | Retail Supplies
Denon rca-970 remote dead are there codes to use in a new oneforall remote
There are so many brand universal remote controls, which have setup codes to Denon. The common setup codes to check with Denon Brand Audio devices are, 0481,0482,0038,0031. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability. for more information go to http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Nov 12, 2013 | Denon 3990944008 REMOTE
I have a freeway car stereo but i lost the remote control, where can i buy that remote control????
Just enter the site linked here. It has setup code list to many brand remote controls. Pull up older posts there. Check the setup code list. See which remote have setup codes to your device.
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 23, 2013 | Televison & Video
How can I re tune a continental Edison tv without the original remote control
The instructions to setup the remote control will be included when you buy a universal remote control. Setup code lists will also be there. Id you want more, check this link. It has setup codes and setup proceedings to different models of remote controls.
Jan 20, 2013 | Televison & Video
I have a Vizio 210 soundbar and the remote control is junk! I want the code the woeks on my Comcast universal remote control.
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)
Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:
Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Nov 14, 2010 | Vizio High Definition Sound Bar
Looking for remote codes for vizio sound bar and comcast remote
Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Aug 28, 2010 | Vizio High Definition Sound Bar
I have a vizio universal remote and the code that works the vizio sound bar is the first one listed under audio/vizio 0660
Oct 16, 2009 | Televison & Video
How to connect the comptroller to the console?
If you are talking about a 360 wireless it wont work. The part that is missing is a small break away cable that connects between the controller and xbox. You can find it on gamestop.com
Feb 02, 2009 | Microsoft Xbox Console
When i set cd rom as my first boot device and if i restart my pc its not booting through cd(for win98 installation)
1, Check if your cd-rom is reading properly, You can do that by connecting the cd-rom to another computer
2. Hope it's the first point because if not, than it's not the cd-rom the problem but the main comptroller on the motherboard. If this is the case then the only alternative is replacing the motherboard.
Jan 12, 2009 | Microsoft Windows 98 for PC
145 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
