Question about HP DeskJet F380 All-In-One Printer
Why won't it print and why is the scanner not working?
    Novelist:
  • 97 Answers
CLICK THE CORNER START ICON TO BRING UP YOUR COMPUTER MENU. SELECT CONTROL PANEL. SELECT PRINTERS AND DEVICES. LOOK AT THE INSTALLED PRINTERS/DEVICES. YOU SHOULD SEE YOUR DEVICE IN THE LIST. MAYBE TWICE, WITH THE SCANNER AND PRINTER LISTED SEPERATELY. ONE OF THE PRINTING DEVICES WILL BE CHECKED WITH A GREEN CHECKMARK INDICATING IT TO BE THE DEFAULT PRINTER. IF YOUR PRINTER IS NOT CHECKED WITH A GREEN CHECKMARK, OR INDICATED AS THE DEFAULT PRINTER IN SOME WAY....RIGHT CLICK ON THE ICON REPRESENTING YOUR PRINTER...A MENU SHOULD POP UP WITH ONE OF YOUR CHOICES IN THAT MENU BEING "MAKE THIS PRINTER MY DEFAULT PRINTER". CLICK ON THE PREVIOUSLY MENTIONED CHOICE AND THEN CHECK THE ICON TO SEE THAT IT IS NOW THE DEFAULT PRINTER. NOW TRY TO PRINT AND SCAN. Sometimes the "print spooler" service in your list of services, (administrative tools in the control panel), is not set to automatically come on when you start your printer. Check and see if it is by accessing your list of services, find the print spooler....right click the print spooler....click on properties. It will tell you what the setting is for the spooler in the properties....if not on automatic, change it to be automatic. Then exit and try to print and scan. Best of luck and be careful when changing settings in your services.
Posted on May 01, 2015
  • HP Master
  • 1,121 Answers
Step1: Check printer is powering on or not., if not check the adapter.
step2. Any error lights are blinking on panel?..check
step3: Cartridges are conditioned or not?.. if not,replace them..
step4: If every thing is fine, check for copying..if copying happens properly..go to next step.. or else go to step2 and check once again properly..
step5: check proper drivers in system., or else
step6: un install existing drivers.
step7: connect usb cable check for new hard ware found popup.. if not check usb cable..
step8:Install full feature drivers from below said link:
http://support.hp.com/us-en/drivers/selfservice/HP-Deskjet-F300-All-in-One-Printer-series/1129389/model/1129390#Z7_3054ICK0KGTE30AQO5O3KA30R1
Sharp mx2300n tray 3
Sounds like you need to configure your print driver with the options that your machine has on it.
Check out my instructions on how to do this!
How To Configure Sharp Print Drivers with Installed Options to print...
Apr 30, 2013 | Sharp Mx-2300n Copier Color Mx2300n...
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
Finger print scanner won't work and can't remember my password - I can only get in to my 'Guest' account. What should I do?
Download and use password recovery software. Download the bootable dvd image and burn it into DVD or pendrive. boot from it and run the software. you can reset your password.
Jul 01, 2017 | Sony VAIO SR Series Notebook PC...
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Dell 1133 won't print the dollar amount on my checks
when you set the printer through the computer did you hit the Apply button....go back and check the settings again you may have missed something
Jun 26, 2012 | Dell 1133MFP Laser Multifunction Printer -...
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
SX515W black cartridge won't print
thake the catridge head out and put it in worm water for 30min dry it and test it if it is not working. it need to be replaced.
Nov 02, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx405 all in one won`t print!
Please re-install the drivers, and follow the instructions as given, you will forge ahead
Mar 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
