Question about Lexmark Office Equipment & Supplies
My Lexmark x2670 does not want to switch on but it flashes the insert paper button and cartridges button
    Top Expert:
  • Lexmark Master
  • 10,875 Answers
Put paper in the cartridges and insert them
Posted on May 01, 2015
3 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Posted on Jan 01, 2008
  • 53 Answers
SOURCE: I refilled my Lexmark cartridge
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Posted on Feb 17, 2011
Lexmark x2670 wont print colour red
You most likely need to go into the maintenance menu on your printer and perform a nozzle and/or head cleaning procedure. Your nozzle for RED is most likely clogged. Printers are designed to be used regularly and when they sit for a whikle unused they tend to get these issues. You may need to do it several times.
Feb 02, 2015 | Lexmark X2670 All-In-One Printer
My Lexmark X4530 wont stay powered up
It insists there is a Cartridge problem on the Printer............ In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Blinking Stopped...........Issue Resolved....... Still Blinking: Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel.......... Now insert it and Power on the Printer and see whether the Lights are still blinking if it is still blinking...... Contact Lexmark at 1-800-539-6275!!!!!
Good Luck!!!!!
Mar 28, 2013 | Lexmark Office Equipment & Supplies
The paper will not feed through the printer
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X2670 All-In-One Printer
The orange paper light with the arrow keeps flashing and my ink cartridges wont come to the center
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 18, 2011 | Lexmark X2670 All-In-One Printer
Printer cannot print test page. Cartiridges not sliing over to load position, "JE" flashing on printer
The "EJ" error code on the display screen indicates that the cartridge carrier has stalled. That explains why the cartridges are not moving to the center when you open the printer cover. Try to check in the cartridge area for a loose encoder strip (transparent strip). Make sure there are no foreign objects obstructing the cartridge carrier's path. If all is clear, close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges. If error continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 05, 2011 | Lexmark X2670 All-In-One Printer
I am having alignment issues with my x2670 printer
What are the versions of your cartridges inserted in the printer? Open the printer cover and remove both cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, reinsert both cartridges and make sure they are properly inserted. Check for any errors. If error continues, please contact Lexmark technical support for additional assistance.
May 16, 2011 | Lexmark X2670 All-In-One Printer
The scanner won't scan when you press the button. how do i fix it?
Try to remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. Close the cover. Disconnect the printer from the power source. Reconnect after 10 seconds. When the printer turns on, reinsert the cartridges and load some paper. Try to scan again.
Since the scanner hardware is also used for the Copy function, can you try to make a copy and see if you encounter any problem.
May 11, 2011 | Lexmark X2670 All-In-One Printer
Paper feed light is flashing yet there is paper loaded.
It could be indicating that there's a paper jam, cartridge problem or carrier stalling. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any debris that may have accidentally fell into it. If none, open the cartridge area and remove the cartridges. Make sure there are no obstructions in the carrier's path. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Load some paper and check if printer is working properly now.
May 05, 2011 | Lexmark X2670 All-In-One Printer
Lexmark 2735 power button flashing
catridges and Turn on the Printer.........
Good Luck..........
Jan 28, 2009 | Lexmark X2350 All-In-One InkJet Printer
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
