Question about Ricoh Aficio Type R1 3228c / 3235c / 3245c Toner - Cyan Edp Code 888343
When i turn on the machine,error shows on the screen,development unit is not installed properly
    Top Expert:
  • Ricoh Master
  • 10,875 Answers
Install the developer correctly
Posted on May 01, 2015
Testimonial: "i have install it properly...but some time error of three toner like K,C,Y, some time show error K,C....some time just K....what is the solution of this error....please help me"
  • Kami Shani
    Kami Shani May 01, 2015
    i have install it properly.....
  •  johnny rebel
    johnny rebel May 01, 2015
    take out all toners,vacuum everything wipe down everything and use can air to blow it out then reinstall toners
  • Ricoh Expert
  • 155 Answers
Reset developer unit if color copier will need to do each one unless it telling which one is not
in properly
Posted on May 02, 2015
1. Defective electrical connection for the TD sensor.
2. TD sensor not installed correctly
1. Take out the dev unit
and put it back in. If that
does not work, replace
the dev unit.
2. Press the TD sensor
firmly against the frame
of the development unit.
Jan 02, 2016 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
How to fix the sharp MX-3100N printer? the message on the screen is install the developer.
Developer unit is not detected , or developer is depleted ( which is very bad , because it could mean that it spilled inside your copier , it is very abrasive)
try removing and re-installing the developer unit , and maybe try using another unit for control,
could also be your harness, see if plug of developer unit is plugged into mainbord
Feb 23, 2015 | SHARP MX-3100N
"please wait" error appears on diplay when i turned on the mfp
Have you had the develop and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready To Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can not print anything unit the F8 is run. Or you start over.
Nov 24, 2013 | Minolta DI2510 Black and White Copier
Sir, Mam, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything unit the F8 is run. Or you start over again with new developer and new drum
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
Please help!!!! I am having problems with a Di2510 machine. When it is turned on I get the 'Please Wait' screen It just stays frozen on that message
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Also try removing the toner bottle, turn off the machine with the toner bottle out and cover closed turn on the machine when it ask for toner properly place the toner bottle in the machine
Aug 11, 2011 | Minolta Di2510 All-In-One Laser Printer
Missing developer unit
Generally this printer can be separate into 4 major part: Printer body, Toner container, Developer unit and Drum unit. The developer unit is the unit where the toner container "mount" on it and it should be removed to allow cleaning task every time the toner container is replaced.
U may get this error message if the developer unit is not install properly after u replace a new toner container. Just lift the developer unit together with the toner container out of the printer and then insert back properly into the machine.
YBC (/\)
Jun 02, 2009 | Kyocera FS-920 Laser Printer
Blinking error light CH will not let machine turn on
side door of copier is open just close it properly .if error stills just check by pressing start key what is sub code if 00 developer unit is missing if 01toner catridge is missing .just check all connectors of developer unit and toner unit.code will bi removed
Jan 20, 2009 | Sharp AL 1631 Copier
MY SHARP AR-5320E COPPIER SHOWING CH ERROR CODE AND BLINKING RED TRIAGULAR LIGHT POINTING TO TRAIL
Some part/ unit (developer, drum, imaging unit, fuser) or something else is not installed properly or is not plugged into the machine. Check all assemblies that can be removed from the copier, and make sure they are installed and plugged in properly.
The 'ch' code will automatically reset when the fault is found.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
YBC (/\)
Jun 03, 2008 | Kyocera FS-920 Laser Printer
Ricoh Aficio Type R1 3228c / 3235c / 3245c Toner - Cyan Edp Code 888343 Logo
751 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
