Question about Pioneer Car Audio & Video
What size does my box need to be built at to get the most bass out of my signal pioneer premier 12 inch subwoffer
  • Pioneer Master
  • 16,632 Answers
You will have to know some specs on that speaker. http://www.diyaudioandvideo.com/Calculator/Box/
Posted on May 01, 2015
WHAT SIZE AND TYPE BOX DO I USE FOR ONE PIONEER TS-W304C SUBWOOFER
You have a lot of choices for this. First, unless you are tuning the sub to a specific frequency you have options. You didn't specify the size of sub so it's difficult to say specifically, but if it's a 12 inch sub, you need about 1.5 to 2 cubic feet. Of course the performance of the sub depends on the music you listen to. If you listen to rock, pop, classical, or country, I recommend a sealed box. A sealed box gives you better control over your sub. The air acts as a cusion and decreases the return time of the cone to rest position. This gives you tighter bass. If you listen to rap or hip hop, I recommend a ported enclosure. This type of enclosure allows for more cone excursion, thus allowing the sub to recreate lower frequencies. Hope this helps.
Aug 12, 2011 | Pioneer TS-W304C Car Subwoofer
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How do I make a sub box for my single ten inch re sx 10 inch sub dat is 1000 rms. Da box needs to be tuned to 35 hz
yeah, you likely cant build a box to tune 35hz... try just building a box that has correct spec by the manufacture for ideal operation, and adjust the gain accordingly, that's where you will attain your desired hertz, oh and by the way hertz refers to signal, and pulse rate,
Sep 12, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
I don't get d true bass quality from my car system...
Firstly, If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches.
May 14, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
If i put the TS-swx310 sub in a bigger box would it get help the sound.......i have a 12'' regular sized box and the speaker is going in a car now???
It is amazing the difference box construction can have on the overall sound of a system. Size is only one factor. Using a larger sealed box may make the sub hit lower, but not necessarily louder. Because the TS-swx310 is a shallow mount woofer, it is designed to run in small enclosure. Putting it in a much larger box could potentially cause damage to the woofer over time. If you want more bass my advice is to use a normal woofer in a box built to spec for it. Generally a ported box will provide more output, and sealed hits tighter. It all depends on the type of music you listen to.
Hope this helps
Please Vote & Rate
Mar 08, 2010 | Pioneer TS-SWX310 Car Subwoofer
To make a box for a single hcca 12 inch
3/4 inch partical board 2inch wood screws,make sure that you read the spec size because thats what makes you deep bass.Peace
Oct 30, 2009 | Orion HCCA 12D Car Speaker
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Pioneer box
Thanks for using fixya!
I have had the same problem that you are having right now. I basically don't know how to start making my own sub box. Well, I chose the Bass-reflex type Box. This the best. Check this link out for a detailed overview of sub box making. http://www.hardwareanalysis.com/content/article/1789/build-your-own-10-inch-subwoofer/
Have a great day.
- HotRatchet
Jul 26, 2009 | Pioneer TS-W307D4 Car Subwoofer
Premier sub used to work great ... now nothing
Did you check to make sure that you didn't blow a channel in the amp? Another thing to check would be the connection on the inside of your box, maybe there is just a wire loose.
Dec 19, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Car Audio & Video Logo
216 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
