My washing machine displays error code f57 what can be the cause of the error
Doesnt want to take in water
    Top Expert:
  • Washing Mach... Master
  • 50,211 Answers
Do not know as there are so many makes and models no water I would replace the inlet valve . http://erepairparts.com/
Posted on May 01, 2015
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    WHAT DOES "OE" MEAN WHEN DISPLAYED AFTER WASH IS COMPLETE.?
    An Error code OE on The LG washing machines simply means the pump is blocked.
    Presumably the water isn't being emptied properly you might have something blocking the pump.
    As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out.
    A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose near the sink waste or somewhere else in the system etc.
    Sep 13, 2015 | Washing Machines
    Bosch washing machine (logixx 8) shows error code F57
    The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
    Feb 13, 2015 | Bosch Washing Machines
    IE error code
    Water inlet error - washing machine failed to fill
    The fault code is displayed, if the washing machine does not detect any incoming water.
    ·Check wiring to water inlet valve
    ·Check water valve
    ·Check drain pump
    ·Check pressure switch
    Check PCB
    Oct 05, 2014 | Daewoo DWDWD3011WW Front Load Washer
    Error f57 siemens WM14S794GB Front Load Washer
    Bosch Logixx 8 Only 4 years old. Inverter Print burned out creating error F57.
    Jul 27, 2013 | Washing Machines
    Ariston AQXXF 129 Error code F 05 - What is this?
    see this causes and fix it. God bless you
    F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
    Potential Causes
    • Check the Water Temperature Sensor, Heating Element and Element Relay
    • Check connections to the Sensor, Heating Element and Relay
    Replace failed component.
    Sep 30, 2012 | Ariston Technologies Washing Machines
    F-05
    F05 machine means "Pressure switch jammed"
    Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
    If not :
    Check if the machine drained, or if water is not being drained.
    If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
    Remove the rubber hose attached to it, and unlock it by blowing into the hose.
    If the water does not drain, this will also cause the pressure switch error.
    In this case check the drain hose , and the drain pump.
    Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
    Apr 01, 2009 | Washing Machines
    Washing Machines Logo
    485 people viewed this question
    Top Washing Machines Experts
