Question about Refrigerators
How old is f & p fridge freezer model N325T? - Refrigerators
  • Refrigerators Master
  • 932 Answers
Go to this link and fill in all of the info at the bottom and they can date the unit for you. Appliance411 Service How old is my appliance Age finder date of...
Posted on May 01, 2015
4 Suggested Answers
  • 29 Answers
SOURCE: The fan in the freezer
it is operated usually off the small pushbutton switch on the freezer door try depressing it and you should hear the fan running if not possibly a faulty fan motor
Posted on Aug 13, 2008
heatman101
  • 43501 Answers
SOURCE: Model N325T. No cold air in fridge or freezer.
Hopefully you read my tip frist and transported it the right way, but since your having trouble probably not.... If you laid it down on its side you have oil in the system where it cannot get out and is plugging the pipes so the compressor cannot run...
Try to let it off ofr about 12 hours before trying to plug it in again...then if it runs... only let it run a few minutes and then unplug it for an hour or two...do this a couple of times and then it will be okay..
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
heatman101
Posted on Apr 18, 2010
Testimonial: "You are correct,fridge was transported on side. Thanks so much for your expert advice. Will do as suggested and pray fridge recuperates. "
  • 884 Answers
SOURCE: N325T water collecting at bottom and back internal wall freezing up
That sounds quite normal as the rear panel is the evaporator skin. Check the drain hole at the bottom isn't blocked
Posted on Apr 22, 2012
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
Apr 22, 2012 | Refrigerators
I have a fisher & paykel n325t fridge. can not get the correct temperature. not cold enough.what should te dial be set at?
if your refrigerator had 7 postions you would set it to 4 check this for me though remove the rear panel in your freezer and assure that you dont have a ice build up on the inside this happens when you start getting a defrost problem also assure when you remove that rear panel that the fan is working the fan blows the cold air into the refigerator side also if youor refrigerator had 4 postions you would set it on 2 send me your model number and check out to see if your starting to get a defrost problem and well go from there thanks again
Rick
if you have an ice build up use a hair dryer to melt the ice this is a temporary fix until we can solve if it does have have a defrost problem or not
Dec 15, 2010 | Refrigerators
heatman101
Apr 18, 2010 | Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Mar 27, 2009 | Refrigerators
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
The fan in the freezer cabinet of Fisher & Paykel Softline refrigerator model #N325T is not running.
Aug 13, 2008 | Fisher and Paykel Refrigerators
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Candy fridge freezer
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Nov 02, 2007 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
