Question about Brother MFC Office Equipment & Supplies
When applying power, the display indicates "closing down all functions" then the printer switches itself off and will not restart. What's wrong?
Canon Mp550 error after i cleaned the print head with soft dry tissues and re install it .U052 the type of print head is incorrect.
A common experience among users of various Canon inkjet printers. The lawsuit settlement is close to being finalized so join soon.
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Dec 27, 2014 | Canon Office Equipment & Supplies
Canon IRC2620 Error Code E000001-0004
This is standard error code for Canon and the fuser unit. The error can be reset by being ready to go into service mode quickly. First press the additional function button, then the 2 & 8 keys at the same time and then the additional function key again. The display should change to the service mode screen, indicating " COPIER " and other accessories. Press " COPIER " then accross the top you should see a menu and select "FUNCTION" then select " CLEAR", then " ERR ", then " OK." This will clear the error from the copiers memory. Turn off the main power switch, wait a few seconds, then turn the copier back on. If you continue to have this error you will have to replace the fixing assembly and if it is similiar to the IRC3220 then you ahve only two screws to remove and the whole unit comes out. You will be saving a service call and I do believe the fuser is over $500. I usually don' tknow the prices of items until I have to do a quote for a customer. Good Luck.
Sep 04, 2012 | Canon imageRUNNER C3200 Copier
I have bought computer speakers x 5 but only have sound out of 3 of them...what am I doing wrong?
You need to go to control panel.
open your sound and audio device icon.
On the dialogue box. scroll down to speaker settings. click on advance.
In The new dialogue box click on the drop down. It Should be indicating Desktop speakers.
Select 5.1 Then click on apply and close it. You should have all speakers functioning. If not restart the computer.
Jan 21, 2010 | Audio Players & Recorders
Will the printer become damaged because repeated error message?
Do a EEPROM initialization:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2009 | Canon PIXMA iP1600 Printer
Mp780 displays "wrong cartridge"
Service Mode: EEPROM initialization
Thanks, Joe
May 24, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
When I switch my windows XP Home Edition on instead of the usual gradual build up to Desk Top & icon programmes etc. I get the usual large black screen but instead of the windows motif appearing I get...
The results you are seeing are actually from the monitor itself. It's telling you the vertical and horizontal sync frequencies to help you troubleshoot your lack of display.
You'd usually see this happen when someone has set the resolution too high, and the monitor just can't handle it.
Power up, and keep tapping F8 until you get a Windows boot menu. Choose "safe mode", let it boot to windows. Go to display properties, and then settings. The slider for the resolution will now be right down. (left-most). Click it once, so that the apply button becomes valid. Hit apply and let it restart.
You should now boot to Windows normally, but with a very low resolution. Go back to display settings and bump it up one step at a time, using the apply button. (which will revert back one step if you don't hit "yes" within 20 seconds).
That way, you can find a resolution that looks right, but isn't too high for your screen.
Aug 22, 2008 | Packard Bell Computers & Internet
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
