Question about Aiwa Audio Players & Recorders
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
A red light shows up, FG-Lock. The turntable starts making noise after finding a track and won`t settle down. Does anybody know how to disengage the FG-Lock?
  • Aiwa Master
  • 5,056 Answers
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
Posted on May 22, 2015
3 Suggested Answers
  • 5 Answers
SOURCE: aiwa lx 70 turntable needle arm
This is not a solution but it is information. I just got one of these turntables and the platter rotates but the tonearm does not move. I took it apart after downloading the service manual and found that there are two small thin rubber belts that due to age have fallen apart and "melt" when you try to pick up the pieces. One controlled the sideways movement of the tonearm "carriage", the other controlled the lifting and lowering of the tonearm. The replacements are expensive (I think around $18 each) and in trying to pop loose a worm gear with a pulley buit into it, so that I could try a cheap rubber band out just to see if the unit would work with new bands, I broke the stiff plastic "retainer" that by its shape was designed to be pushed out of the way a bit to allow the worm gear to be removed. The service manual, by the way, had all sorts of information about how to make fine adjustments, but said nothing at all about how to replace the belts. Unless removed there was no way to put the replacement band in place over the gear/pulley combination because there was no exposed end to slip a complete band over. So I think it was a bad design, made worse by the aging of the components that made the bands melt and the plastic "keeper" brittle so that instead of flexing out the way it broke. So I'm going to recycle the components. I did not find any reviews to tell me how good a component unit this was, so before you hire a pro to try to fix this unit you need to figure out if it will be worth it to you in the long run. Anyway, good luck.
Posted on Apr 12, 2011
SOURCE: AIWA LX 70 TURNTABLE THE
Hi jun_tradjazz,
I have an LX 70. There are two drive belts. They are identical and of a standard size, ie., not specific to Aiwa, Quite few years ago these belts wore out on my deck. They became smooth and the pulley wheels began to slip. I was lucky that a local electronics shop in town (Belfast,NI) had spares and replaced them "off the shelf". Sadly they can't do that now.
There are specialist retailers on the net who provide all sorts of drive belts of this type. The trick is to find the spec! Perhaps, if you contact them, they might be able to match a new belt with one of the belts on your machine.
From memory, replacing the belts is fiddly, but not very difficult if you are patient and examine the mechanism carefully.
Although I now use a Rega Planar 3 with motor upgrade and a Rega Exact stylus , I still love the magic of the LX-100 and cannot bear to part with it. A beautiful piece of design with it's link to the Strathean Audio (a Belfast HI-fi company, now defuct) direct drive system that it employs.
Good luck with your search.
Pat Cree
Posted on Oct 12, 2011
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Record player skips frequently
I used to tape a coin to the end of the arm.
Nov 30, 2013 | Audio Players & Recorders
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Sony PS-LX250H Player arm won't set down to play
Have you made sure the "up/down" button is not depressed? It's the furthest button to the right of the player if you are looking at it head-on. If it is depressed, it will cause the needle to simply hover above the spinning record. A good thing if you want to "pause" your musical experience, but not much help if you are trying to enjoy some sonic sensations.
Nov 23, 2012 | Sony PS-LX250H Turntable
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
AIWA LX 70 TURNTABLE THE BELT THAT MOVES THE ARM TO THE RECORD IS BROKEN. WHERE CAN I BUY ANOTHER ONE, AND IS IT EASY TO FIT
Hi jun_tradjazz,
Pat Cree
Aug 11, 2011 | Aiwa PX-E860 Turntable
Aiwa lx 70 turntable needle arm
Feb 15, 2010 | Aiwa Audio Players & Recorders
No sound from speakers when turntable playing records
hi,, please check your RCA cable...or replace it possible...
Mar 12, 2009 | Aiwa PX-E860 Turntable
343 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
