Question about Miscellaneous
My Trauslen G20000 works fine for a few days, then randomly shuts. I switch outlets and the unit usually works well for a couple of days before then it shuts off again.
I have used 3 different outlets all with same results. The breakers and electrical in my bakery are not the issue, as far as I can tell. I have not tried to mess with any settings, just simply plugged the unit into a new outlet to temporarily "solve" the problem.
  • 5,323 Answers
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
My Trauslen G20000 works fine for a few days, then - trauslen-g20000-works-fine-few-days-gmwnj2kdsljwfny5himmg2xx-1-0.jpg
trauslen-g20000-works-fine-few-days-gmwnj2kdsljwfny5himmg2xx-1My Trauslen G20000 works fine for a few days, then - trauslen-g20000-works-fine-few-days-gmwnj2kdsljwfny5himmg2xx-1-9.jpg/uploads/images/trauslen-g20000-works-fine-few-days-gmwnj2kdsljwfny5himmg2xx-1-9.jpg
Posted on May 18, 2015
DLE9577SM Power issues. Control board?
  1. Power the dryer OFF and unplug it from the electrical outlet (You can also trip the circuit breaker if that's easier).
  2. Press and hold the START/PAUSE key for 5 seconds while the unit is without power.
  3. Turn the breaker back on, and power on the unit.
Mar 29, 2017 | LG Dryers
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
Dehumidifer will not turn on. An E2 code comes up on the panel. Has been working fine for 4 day.
Since it has been working well for 4 days, it may be a case that the unit needs to reset itself. To accomplish this, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that timeout allowed the unit to reset itself. Also, check to make sure that the water collection bucket is installed properly and is making good contact with the safety switch.
Hope this helps you solve the problem.
Apr 27, 2011 | Haier 45-Pint Dehumidifier
My Goodman model GMS90703BXA has a problem wherein after a cycle, the ventilator / discharge fan doesn't shut down properly. It stays on after the burner has shut off and after the main fan has shut off. ...
Hello, usually this happens when the pressure switch remains open, this could be due to a blocked flue pipe, water inside the tube between inducer motor and pressure switch, or the switch itself is going bad. Condensation can form and leak back to the pressure switch through the tubing and causing an intermittent problem with the inducer motor running continuously
Mar 01, 2011 | Goodman GMS90703BXA Heater
After a couple of hours, the ground switch on my electrical system shuts the fridge down. I can use the frige fine on a none grounded outlet. if I disconnect the ground wire it works fine. Probably a...
The problem most likely would be in the defrost system. Many systems use a coil that heats to defrost the ice from the coils...
If a wire is broken or just a wire touching metal it would kick the outlet....
It also would take about three to four hours before the defrost would turn on....
So there is where I would be looking....maybe even disconnect the defrost for a day to see if it solves the problem or not....
heatman101
Nov 18, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
My unit will shut down completely periodically
Some appliances do not work well when used on a gfci protected circuits. Move the microwave to an outlet that is not reqiured to be gfci protected and it should work fine . If you do not have a dedicated outlet for your microwave , it is a good idea to install one , or have an electrician install one for you.
Jan 07, 2010 | GE JVM2070 Microwave Oven
Kenmore Upright Freezer Works Sometime
try a new start relay and overload kit specifically for the make and model freezer you are working on. if compressor can be seen ,the numbers on it can be used to get correct oem start cap, relay ,and overload. if your unit is having starting problems that will usually fix it. if however, the stat is failing to bring it on a new stat is called for. but it sounds like it is having starting problems since you said it was off a long while then still struggled on the overload to start then finally did. if the new start components don't work then new freezer time. compressor replacement is to expensive anymore. good luck
Oct 27, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Dynex Te685avr backup battery doesnt work
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
The model of the battery is a WKA12-7.5F2 and can be purchased at: http://www.replacementupsbattery.com/Product_pages/wka12-75f2.html.
Jun 26, 2008 | Dynex (TE685AVR) UPS System
FX-160 not working
Check your voltage in your area or check your outlet it may be loose. If your outlet is loose try using another outlet to test the unit.
May be the unit is tripping due to abnormal voltage or loose outlet.
Dec 29, 2007 | DeLonghi Pinguino PAC-02 Air Conditioner
Miscellaneous Logo
32 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
Philippe Dekyvere
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
