Http://www.carlsalter.com/download.asp?p=1828
Here's a link to a free manual laura
SOURCE: Exhaust
the best way to do this is buy the aftermarket exhaust and keep the baffles in the exhaust and run it for 50 or so mile then pull out one of the plugs and if its gray you are fine if its white or black you will have to rejet
SOURCE: 2002 Yamaha V-Star Classic 1100 Will not run over 70 MPH
The first thing you need to check is the air filter. Sometimes critters can get into the airbox when a bike sits for awhile. Sounds crazy, but it has happened to me. If nothing is blocking the filter, give it a quick clean since you have it out.
Next things to check:
Faulty diaphragm
Improperly adjusted fuel level
Clogged or loose main jet
Faulty fuel pump
You may not be able to check these on your own, but these are the next likely culprits.
Hope this helped
SOURCE: Yamaha FZ400 manual
Google " service manuals yamaha "
or go to www.repairmanuals.com
or try your local library. Often guys will donate manuals to the library.
You might find a free pdf service manual on this site, they have a ton of them.
http://www.carlsalter.com/motorcycle-manuals.asp
SOURCE: Yamaha 1100 Drag Star 2001 Custom motor starter,
These parts are fairly reliable. Rather than buying new, you should be able to pick one up from a motorcycle breaker who will post it to you. I would expect to pay about £60-£100 tops in the UK (Depending on mileage). ANy Yamaha dealer will be happy to order you one new, but they are a hell of a price!
