Why are the power and start buttons not functioning?
Error 5b00
Hello, your error is about the ink absorber.
"Ink absorber full Japan:
[5B00]
Others:
[5B01]
P07 The ink absorber
becomes full.
Replace the ink absorber (ink absorber kit), and
reset the ink absorber counter."
This is the way to enter service mode:
"Start the printer in the service mode.
i. With the machine power turned off, while pressing the Stop/Reset button, press and hold
the ON button. (DO NOT release the buttons).
ii. When the Power LED lights in green, while holding the ON button, release the Stop/Reset
button. (DO NOT release the ON button.)
iii. While holding the ON button, press the Stop/Reset button 5 times, and then release both
the ON and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm
and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm
LED.)
iv. When the Power LED lights in green, the machine is ready for the service mode operation
and "0" is displayed on the 7-segment LCD.
2) Start the Service Tool on the connected computer.
i. When a button is clicked in the Service Tool dialog box, that function is performed. During
operation of the selected function, all the Service Tool buttons are dimmed and inactive.
ii When the operation is completed, "A function was finished." is displayed, and another
function can be selected.
iii If a non-supported function is selected, "Error!" is displayed. Click OK in the error message
dialog box to exit the error."
You can use the service tool to reset this error after you have enter service mode.
here is the service tool:
http://www.4shared.com/file/QptYmQTM/ServiceTool_V1074planet.html?
Nov 03, 2013 | Canon PIXMA MP180 All-In-One InkJet...
Press start button and nothing happens.
Hi Dopey,
You may try the following solutions:
1. Open the start button and clean the connectors inside. If there is a dust withing the switch, it may not work.
2. As the start button is connected to the starting motor, please check if the motor is functioning ok.
3. Also check if you battery is fully charged as the starting motor needs more power than other functions on the motorcycle.
Hope this will help you.
Regards
Nat
Jun 29, 2012 | Suzuki Motorcycles
Ink absorber problems
Your ink absorber is almost full so you need to reset your printer... Follow the instruction given below:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Aug 27, 2011 | Canon Pixma iP4500 InkJet Printer
I have a Sony Cdx-gt300. When the head unit receives power it turns on, the clock shows, and then the Radio functions scroll continuously. The radio has been reset a dozen times at least. I have also...
you might have a button stuck, try gently pulling the function button out a little bit. i used a sheet rock knife razor blade and was able to release it but after pressing the function button again it started all over again. good luck.
Mar 26, 2017 | Sony CDX-GT300 CD Player
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
The scan function won't work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated.
the scan function won\'t work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated
Dec 03, 2010 | HP DeskJet F4280 All In One Printer InkJet
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Printer not working.
i. With the printer power turned off, while pressing the Stop button, press and hold the ON
ii. When the Power LED lights in green, while holding the ON button, release the Stop button.
iii. While holding the ON button, press the Stop button 2 times, and then release both the ON
and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
Without the scanner (connect the operation panel unit.);
While holding the ON button, press the Stop button 3 times, and then release both the
ON and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power
LEDs light alternately, Alarm in orange and Power in green.)
iv. When the Power LED lights in green and "Service Mode Idle" is displayed on the LCD, the
printer is ready for the service mode operation.
(7) Main Main ink absorber counter
resetting
Set a sheet of A4 or Letter sized plain paper. After
the ink absorber counter is reset, the counter value
is printed automatically.
(8) Platen Platen ink absorber
counter resetting
Jul 06, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon IP 3000 - ink absorber full
<Service mode operation procedures>
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
Power button.)
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
Jul 02, 2010 | Canon PIXMA iP1300 Printer
Waste ink tank full, what do I do?
Aug 02, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
jasbo
jasbo
