Question about Eclipse Car Audio & Video
Have 2 -12" inch eclipse sw6200 with two positive and negative hook up idk how to hook up from amp
    Sergeant:
  • 300 Answers
It will depend on the capability of your amp. Each sub has dual voice coils (DVC). Each voice coil is (probably) 4 ohms. If your amp is a single channel, 1 ohm stable amp, you can connect all of the voice coils from both subs in parallel on the amp output. Other configurations will depend on the amp's number of channels and minimum resistance your amp can withstand.
Posted on May 07, 2015
  • 10 Answers
SOURCE: Car amp re conecting the the battery
Hook up the battery, (the negative post) and then put the fuse in. This is the best choice because if you put in the fuse and then put the negative post back in and the wires slip when putting in the negative post, the fuse might blow due to the sparks. You will then need to get another fuse, which also mean sending more money.
Posted on Dec 04, 2007
SOURCE: how do i set this up in my home
You could use either or both. I would use the charger in the house. The only thing is that if you have a big amp, the charger may not work at high volumes because the bass may draw too much power. The best way it will work is to hook them both together but I dont recommend you charging a batt in the house.
Posted on Mar 07, 2008
sicaudio
  • 96 Answers
SOURCE: problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Posted on Jan 10, 2009
  • 10 Answers
SOURCE: my sony 4 channel 600 watt amp keeps going on
sounds like amp is grounded
Posted on Feb 19, 2010
SOURCE: only one sub works
i have 2 subs and 2 amps both wired properly but one bose not seem to run how can i fix the problem please really stuck?
Posted on Mar 22, 2010
How should i hook up a visonik class D vxd709 to my dual voice coil 12" Treo subwoofer?
if your amp is a monoblock 2 ohm stable amp wire the coils positive to positive and negative to negative into a single channel that will create a 2 ohm load turn your amp down and adjust by ear till it sounds good if your amp is a 2 channel amp 4 ohm per channel wire each coil one per channel turn amp down and adjust by ear till sounds good hope i was helpful
Feb 17, 2013 | Car Audio & Video
How do I wire a pair of type r 15 inch woofers to 2 pdx 1.1000 amps for maximum bass output
are u trying to run one speaker of each amp if so the should be dual voice coil jump one positive to the opposite side negative then take the positive thats not hooked up from one side and the negative thats not hooked up from the other side and run them to the amp but turn ur amp down all the way and work it up because one speaker will not handle all the power from one amp
Mar 30, 2012 | Alpine Car Audio & Video
What's the best way to hook up 2 Hifonics hdl12d4 subwoofers to a mono amp
Ok, your post has two different models listed. Let's start with something you need to know about your amplifier. Is it one ohm or two ohm stable. This will make a difference. Also, whether your subs are single voicecoil (HFI12s4) or dual voice coil (HDI12d4).
Let's start with the easy scenario. Let's say your amp is two ohm stable and you have two single voice coil subs. It's simple. You go from the positive of the amp to the positive of both subs and the negative of the amp to the negative of both subs. This will provide a 2 ohm load to the amplifier, thus pulling all the power out of it.
Unfortunatley, if you have two dual voice coil subs, you won't be as efficient. You will only have the options of a 4 ohm load or a 1 ohm load.
This is where having a one ohm stable amp would come in handy. If the amp is one ohm stable, hook the positive of the amp to all 4 of the positives on the subs, and hook the negative of the amp to all 4 negatives of the subs. This produces a 1 ohm load.
WARNING!! If you have a 2 ohm stable amp DO NOT use the last wiring scenario. It will fry your amp.
Now, the last is a little trickier. This is for two dual 4 ohm subs. Follow closely. Hook the positive of the amp to one of the positives of each sub. (do the next step to both subs) Go from the negative of the voice coil that you hooked positive from the amp is hooked to, and hook that to the positive of the unused voice coil. Then go from the negative of that voice coil and hook to the negative of the amp. Make sure this is done on both subs. This will give you a 4 ohm load.
Hope this helps
Aug 31, 2011 | Hifonics HFI 12S4 12 DVC Subwoofer 600...
How do i connect a single 12" subwoofer to an Eclipse PA5422 amp?
Make sure your switch on the amp is on lpf (low pass filter)....You should be able to bridge that amp....Look where you hook up speakers and see if it has a line over one negative and one positive....Should be outer two screws.
Oct 16, 2010 | Eclipse PA5422 Car Audio Amplifier
Battery wiring
Series or paralell?. Should be parallel so you get 12 v0lts. two positives together and two negatives together
Sep 26, 2009 | 2001 Toyota Land Cruiser
How do you hookup 2cvr 12 to a mono amp?
Hook together both positives from each speaker together and both negatives from each speaker together and hook them up as one connection to your amp.
May 18, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
Need wireing diagram for hooking up two as12sq 12-inch square 2
you can run each sub at either 4ohms or 1ohm which means that two of them will run at either 2ohms or .5ohms....be careful how you wire them because most amps cannot handle .5ohms very well and might blow.....to wire them for 2ohms you will need to wire each sub the following way. they have two voice coils make a jumper wire connecting the negative on one coil to the positive on the other coil. what you are left with is a coil with an open positive and the other coil has an open negative. when both subs are wired like this connect the two positive terminals together (1 from each sub) and the two negative terminals together (1 from each sub) now the subs should be wired together at a 2ohm load. run the two positive wires into another combined wire which will run to the positive speaker terminal on the amp. do the same for the negatives
Apr 17, 2009 | Hifonics AS12SQ Car Speaker
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Wiring
You may be surprised to learn that even though there is a negative and positive on the sub it usually dont matter all that much because that amp allows you to switch the polarity of its outputs to allow your mids to sound better... anyways on to your question To wire a sub it depends on how many you have, if they are dual or single voice coils, what impediance your amp is stable at. Tell me what type of amp you are hooking this subwoofer up to and how many are being connected. And ill try and give you the best way to connect the sub(s) to your amp.
Mar 25, 2007 | Rockford Fosgate RFP 2418 Car Subwoofer
Car Audio & Video Logo
186 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
