How do I fix my computer?
How one replaces the processor?
  • Brad Brown May 01, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What make and model
    Sergeant:
  • 291 Answers
Seeing a repairman does cut to the chase. Here are a few things you can try.
First, check your physical connections on the computer. Yes, I mean cables and power cords --to see if they are all firmly plugged in.
However, if you can google the symptoms that your computer is showing when you try to use it, you might get a helpful tip. --Or you might get into more trouble. IF you get your computer running, save any critical information to a USB stick before you take another step!!! That means documents, passwords, software keys, personal photos, bookmarks or favorites.
That said, if your computer can get to System Restore, you can try using a restore point date that preceded the problem. But before doing that, you might try uninstalling a recently installed program, rebooting, and seeing if the problem vanishes. Revo Uninstaller is good for removing programs. And, you can try running Malwarebyte's Anti-malware to see check for infection. Also, you might want to disconnect any new hardware that you have recently attached to the computer and see if the computer will then boot correctly.
Most computers have a recovery partition, that is, way of returning the computer to factory defaults, just as it was on the shelf before you bought it. That will erase any program or Windows updates you have subsequently installed. and you have to be prepared to reinstall such. You may be able to see a number of recovery options by repeatedly hitting F8 when your computer is booting. Using the last good registry can sometimes fix a problem.
Noe of these suggestions actually test the hardware. If your drive is making a clicking sound, it may have failed. If so, that hard drive is unlikely to rise from the dead. New HD or new compujter.
Posted on May 04, 2015
  • Lars Olsson
    Lars Olsson May 04, 2015
    YOU DID NOT ANSWSER THE QUESTION HOW TO CHANGE PROCESSOR.
  • rythot May 05, 2015
    Opps, I missed the processor part of the enquiry. Identify the current processor and motherboard specs, maybe download HWINFO and run it. You have to know if the new cpu is compatible with that motherboard. Check the manufacturer of the motherboard's website. Here are some procedures but this is probably work for a tech. http://www.wikihow.com/Upgrade-a-Process...
    Brigadier General:
  • 3,400 Answers
SE A PC AND REPAIRMAN.
Posted on May 03, 2015
Hi....how can i repair my processor it is very fast to heat..then my computer is shut down....but i try to change my board... it is sane problem
remove the processor heatsink and the processor clean the surface and apply a thin layer of heat sink compound and fix back the processor and also check the processor fan is working if the processor is fauly the processor heats up quickly and shutdown the computer
Aug 04, 2011 | Compaq Pentium II , 266 MHz Processor
Sir procceser fix the board and . suddenly damage the the board and not come a disply which problem
If you have replaced the processor and have fix it then suddenly after a while the display in your monitor is gone, the video card in your motherboard could have come loose.
Detach this video card from the motherboard and reseated this properly.
Make sure also that the vga cable is fix properly on both the video card and the monitor.
Post back if you still have problems.
Feb 08, 2011 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
My computer keeps rebooting my itself
remove all the addon cards and power to the hard disk and cd drive and restart your computer if the problem still persists remove the cpu fan and cpu from the sockets and re fix the processor to the socket and clean the surface of the processor and the heat sink apply a thin layer of heat sink solvent and fix the tightly to the socket remove the memory card and clean it with a clean cloth and replace them to socket and switch on the computer if the problem priests replace the processor with your friend that fixes the socket and restart the system
Nov 26, 2010 | ASUS Eee PC 1000H Laptop
I have a pentium 4 2.4 Ghz. processor.My computer
just reset the bios setting and also remove the cpu and fix it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 25, 2010 | Intel Pentium 4, 2.4 GHz Pentium 4-M 705...
When strting up the computer stops at the screen where one chooses SAFE MODE etc.... It had a FREEZING problem. I did full windows xp pro REPAIR. Even when using a NEW drive and installing FULL NEW...
hello, remove your processor, blow the processor sit, wait a for some time and fix back the processor. this always happen when the processor is getting tired(old).or when the cpu is dusty
Aug 12, 2009 | Computers & Internet
Vertical lines on screen , is there a processor driver download to fix this problem
Vertical lines on a screen is not a processor problem, vertical lines is going to be a problem with the monitor or the video card. Try a different known working monitor on your computer and if the lines go away then you know that the original monitor is bad.
If the lines don't go away then try replacing the video card. If you have integrated video then the motherboard would need to be replaced. A processor driver download is not going to fix a vertical line problem.
Aug 08, 2009 | Dell Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
