Question about Apple iPhone Cell Phones
IPhone is saying it's connected but not charging why?
    Problem Solver:
  • 6 Answers
This may be due to the charger itself. Overtime they can stop working. Or it could be your phone not registering it. You can try these following steps. https://support.apple.com/en-us/HT203030
Posted on May 04, 2015
Iphone charging
Are you charging with usb? Sometimes it doesnt get enough pwer over usb so you may use the ac plug instead. If you experience that too, just leave it connected to the pc thru usb for sometime. Pls turn it off first. it could come up anyway.
May 02, 2013 | Apple iPhone 3G
Iphone will not charge..... message says charging is not supported with this accessory.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 21, 2012 | Apple iPhone4 4G iPhone 4
My iphone was charged up then it went blank then wen i put it oo the charger its saying connect to itunes
You seem to have either entered restore or dfu mode your going to have to restore your phone
Feb 28, 2011 | Apple iPhone Smartphone
I repaired my lcd on my iphone 4g and now it wont sync to my computer or even charge however if i conect it to my wall usb charger it comes on and says conect to itunes
The dock connector is not connected properly or maybe the ribbon cable was damaged. The guide to re-assemble it properly is here: http://portatronics.com/guide/
Jan 07, 2011 | Apple iPhone Smartphone
My iphone says "charging is not supported with this accessory"
The device you have connected your iPhone to will not charge it. But it may still work (just not charge)
Dec 25, 2009 | Apple iPhone Smartphone
Battery life less than 12 hours; Wifi says "UNABLE TO CONNECT"
This is a really good article that will take you step by step through the settings that will best optimize your battery life. And if this doesn't help you should make an appointment at your local Apple store, they are always very helpful (at least in my experience).
http://www.apple.com/batteries/iphone.html About iPhone BatteriesLearn how to maximize the lifespan and battery life of your iPhone.
Nov 09, 2009 | Apple iPhone 3G
What do i do when i my ipod touch says ipod touch says ipod is disabled
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 07, 2009 | Apple iPod touch
How can i fix and ipod touch that says ipod is
You'll hv to restore the ipod..here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6
Aug 26, 2009 | Apple iPod touch
My IPOD touch is locked and my daughter forgot the passcode. We don't have access to the computer with the original itunes. The IPOD says to connect to itunes. itunes says it cant connect because there...
all you hv to do is go thru the earlier posts with the same problem....anyways here's the solution again...
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Aug 15, 2009 | Audio Players & Recorders
Cell Phones Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
