No horizontal convergence - Televison & Video
  • Brad Brown May 01, 2015
    Hi eid shriba, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and model
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
Convergence correction circuit has the fault. Contact any service technician to get it repaired. This is not a user repairable work.
Gopakumar Gopalan Google
Posted on May 01, 2015
Sony kp-46v15 convergence problem dont know were to start on adjusting main convergence board in front were do i start there is 15 or so red green blue ajustments for horizontal and the same for vertical...
Do not mess with those, they don't just go out. they are also for skew linearity, heighth, width for vertical and horizontal adjustments. If your convergence went out need to find convergence circuit and look on the plugs for your vcc voltages going to the convergence circuit. If missing, trace back to power supply and look for an open low value resistor.
Apr 20, 2011 | Sony KP-46V35 TV
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    Where are the convergence chips located on my 60PP9202 for the red
    There are 2 Convergence Chips: 1 for Horizontal (it includes Red, Green and Blue Convergence channels) and 1 for Vertical (it includes Red, Green and Blue Convergence channels). Horizontal Convergence Chip is 7044 and Vertical convergence Chip is 7045 (both STK392-120). They are fixed in same "big" Heat Sink, with a 2 metal black clips, from Video Inputs board side.
    Oct 19, 2009 | Philips 60PP9202 60" Rear Projection...
    Remote will not adjust red convergence/multi-point horizontally
    check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
    Jan 17, 2009 | Philips 55PP9352 55" Projection Television
    Convergence difficulty
    If the red convergence will not move horizontally then no there is nothing that can be done except for a repair. This should run you $300-$500 depending on the service man and area you are in. Good luck if you need more help please ask.
    Tim
    Sep 10, 2008 | Televison & Video
    Red Convergence on JVC AV- 65WP74
    convergence amp ic bad
    http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
    http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
    Sony Convergence
    http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
    http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
    Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
    No horizontal red convergence control
    Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
    Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
    Televison & Video Logo
    35 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
