What is error 0002? - Office Equipment & Supplies
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
Error 0001 error 0002
I have looked through the Service Manual for you and there does not seem to be an error code 0001! or 0002. Are you getting any sound Bleeps? Or flashing Orange or Green lights?
Mar 10, 2014 | Canon PIXMA MP830 All-In-One InkJet...
How do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
tomas
how do I solve error code 0002 on my epson pro 9800 maitenance error code 0002 unable to print
Solve this problem:
Aug 02, 2010 | Epson Stylus Pro 9600 InkJet Printer
I want to find out what a report suspended error 0008 is and how i can get rid of it. Canon photocopier 2018i
ARE YOU SURE THAT IS E008?
hERE ARE THE ERROR CODES FOR 2018
E196 0001 Error on writing and readout ROM of image processor PCB (main ROM).
0002 Error on writing and readout ROM of image processor PCB (option ROM).
E261 0000 Zero-cross signal error
E540
E542
E730 0000 Inside error of the image processor PCB (PDL system error)
E744
0002
0003
0004
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error E00025-002
Product : imageRUNNER 5570 / 6570 Title : E025-0002 Error :
E025-0002
Workaround :
It has been found that if the toner bottle is not installed properly E025-0002 may occur.
May 07, 2009 | Office Equipment & Supplies
Error Code E000514-0002
514-0002 is a finisher error in the finisher
The delivery belt does not return to home position when the stack delivery motor is driven for 3 sec.
Main problem The stack delivery motor is faulty. The delivery belt home position motor is faulty.
Try to check motor & sensor or operate copier without finisher.
Dec 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Error message : E000025-0002 on my canon imagerunner 5070
rep
Nov 26, 2007 | Canon imageRUNNER 5000 Copier
27 people viewed this question
jasbo
jasbo
