Question about Rational USA, Inc SelfCooking Center Combination Oven - Electric - Holds 20 Steam Table Pans RAT-SCC201
Hi. I have a Rational Scc 201 from 2010. the last dysplay doesn't work. what shoul i do?
  • Albert Ten
    Albert Ten May 01, 2015
    the touchscreen doesn't work.
Rational SCC 101 showing service 100.
Exactly, what do you need to know? Your inquiry does not provide any clues as to what information you need.
Mar 23, 2015 | Computers & Internet
What are rational numbers
Use the words: decimal part, not decimal fractin
Any number whose decimal part is periodic (has a recurring pattern that repeats indefinitely) is equivalent to a rational number, IS a rational number
0.345 345 345 ... =345/999=115/333
In the following screen captures, discard the last digit if it does not belong to a period. It is the effect of rounding up of the calculator
Period is 345
Period is 1
Period is 09
Period is 79
In general, if you have a decimal part of the form 0.d_1 d_2 d_3....d_n d_1 d_2 d_3 ...d_n ... where d_1 is the first digit of the period, d_2 is the 2nd digit of the period, ..., d_n is the n-th digit (and the last one) of the period, then the fraction representation of
0.d_1d_2...d_n d_1d_2... d_n ...=(d_1d_2...d_n)/(99...9) where the number of 9's in the denominator is equal to the number of digits in the period.
Once the fraction is found, one should reduce it to its simplest form.
Mar 02, 2014 | Office Equipment & Supplies
Rational scc 101g hot air fan wires disconected
the water is going to the ice maker I have tried every thing i can think of
Feb 27, 2014 | Kitchen Appliances - Others
Gas restart
your igniter pcb may be faulty
Feb 02, 2014 | Rational USA, Inc SelfCooking Center...
WHAT is error 51 on a rational oven
Error 51 doesn't exist on SCC and SCC_WE models. If you are referring to a Combi-master or Combi-master Plus (CM or CMP) then error 51 means the battery on the control board is below 1.5 volts and should be replaced. Go to your local electronics or grocery store and buy a CR2032 battery, it looks like a quarter. Open up the front control panel and replace the battery.
Feb 26, 2013 | Microwave Ovens
Scc-101 rational fault codes
Rational SCC error code service 100
Aug 27, 2012 | Ovens
Rational scc elec showing 34 -2 fault maybe on buss cable , which buss cable ,will show this fault code
hi . yes could be buss cable or more likely the fan blower motor , if light is flashing on motor pcb, carl (catering eng)
Feb 03, 2012 | Kitchen Appliances - Others
I need to replace a Samsung SCC-641 can't seen to find any online.
I have two non working cameras with working power control plates if you are interested. Contact pbyer14@gmail.com
Jul 19, 2010 | Samsung Power Supply, Control Plate for ...
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 | Ovens
Water is pouring out of the bottom of Rational oven SCC 101 E
theres a chance you have a deffective solenoid staying open causing the water to overfill the boiler tank and passing out the overflow into the quench box and down the drain!
Mar 11, 2010 | Ovens
Rational USA, Inc SelfCooking Center Combination Oven - Electric - Holds 20 Steam Table Pans RAT-SCC201 Logo
513 people viewed this question
Top Rational USA, Inc Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Rational USA, Inc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
