Question about Whirlpool Washing Machines
I just asked a question about a stuck inner basket on a Whirlpool Washing Machine. What happened to my question ?
  • Whirlpool Master
  • 5,323 Answers
What makes u say its stuck? is it just not spinning, or wash agitating? do u hear noise? might have bad bearings or drum spline is damaged
I just asked a question about a stuck inner basket - just-asked-question-about-stuck-inner-fgv1ctnzjgewe3hu2qpqylbk-3-0.jpg
Posted on May 08, 2015
  • Jorge Rendon
    Jorge Rendon May 08, 2015
    sorry forgot to add these pics
How do I remove a stuck inner basket on a Whrilpool Washer Model GSQ9364HQ0, Serial CK0946360 ?
You are going to have to lay the machine down and work from the bottom to pull the transmission and shaft out of the drum.
May 01, 2015 | Washing Machines
Removing stuck shaft from Cabrio Washing Machine
use a bottle jack, brace the basket and use the hydraulic power of the bottle jack (halfords sell them cheap)
Dec 07, 2013 | Whirlpool Washing Machines
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking from my washing machine when I am washing clothes and I keep getting the LD error code and UL but it is not unbalanced.
Grab hold of the inner basket & pull up & down. Does it move up & down? If not clothing is stuck between the inner & outer basket. Tilt the unit back & use a flash light & shine it through the clear plastic & see if you see clothes in it.
Sep 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
In the middel of the wash it stops and the creen haas a fon it?
Tilt the unit back & shine a light through the clear plastic of the outer basket & see if you see clothing stuck in between the outer basket & inner basket. The floating basket should lift up & down if you grab the inner basket from the inside & lift up.
It throws a code oL it means over load and there's nothing it it but water so how can it be reset please
Tilt the unit back & shine a flash light through the clear inner basket & see if there is any clothing stuck in between the inner basket & outer basket. Open the lid & lift up on the inner basket It should move up & down.
Remove the drum on a top loaded washing machine
odds on something being between the tub and basket is very small.  noise probably coming from brake/clutch or transmission just to name a few possibilities...
Jul 24, 2010 | Whirlpool Washing Machines
Whirlpool top loader washing machine needs clutch
also check drive block for the inner basket to make sure it is ok.drive block is under the agitator.remove agitator with 7/16 socket.
Mar 03, 2010 | Washing Machines
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
